Old 01-03-2004, 02:53 AM   #1
68c10owner
68c10owner's Avatar
heater blower motor question
my heater doesn`t blow hard enough to keep the truck warm. does anyone know where i can get a new blower or any other tips/tricks to get this thing blowing better? oh yeah, it`s a 68 non a/c. thanks
Anthony
Anthony
68c10owner is offline   Reply With Quote
Old 01-03-2004, 03:05 AM   #2
JOE BOB
Anthony, I have read on the baord here that certain year Cadillac's are a perfect fit, but are more powerful. Also, is there a different blower motor to order for an A/C truck? I would imagine they would be more powerful. Good Luck, Joe Bob.
JOE BOB is offline   Reply With Quote
Old 01-03-2004, 03:10 AM   #3
Solver
Solver's Avatar
either your high is out on your switch or my best bet is that your full of leaves and debris in the heater box. They plug up after a few years of leaves and such falling down the cowl.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 01-03-2004, 03:15 AM   #4
scott67swbtx
I had the same problem with my heater about a month ago...mine was not blowing hot air ...ended up pulling heater assembly(inside engine compartment) found birds nest in there.....blows pretty hard now and a hole lot warmer
scott67swbtx is offline   Reply With Quote
Old 01-03-2004, 04:35 AM   #5
68c10owner
68c10owner's Avatar
thanks for the info guys. whats the easiest way to get into the heater box and how do i test the switch? thanks again,
Anthony
Anthony
Old 01-03-2004, 07:23 AM   #6
GMC Jim
GMC Jim's Avatar
There is a considerable difference in A/C and non A/C blower motors....The Heater only blower motor specs are :- 6.25 amps max and 2550/2950 min/max RPM. The A/C blower motor:- 16.5 amps and 3700 RPM min. Most GM blower motors are interchangeable and can be gotten quite reasonably from most salvage yards.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 01-03-2004, 11:42 AM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
But is a used one worth the trouble when a new one is less than $20. I got a new one from NAPA last year. They no longer differentiate between AC or nonAC. They were all AC versions and boy do they BLOW. It was like a wind tunnel with the new blower motor.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-03-2004, 12:40 PM   #8
Huck
Huck's Avatar
If you have tons of junk in the air passages, a new fan motor may not help much. As I recall (somewhat foggy here) you can pull the fan motor on a non-A/c truck without too much trouble from under the hood. May have to remove the hood hinge asm. On A/c trucks believe you need to drop the pass side inner fender a bit by removing the rear bolt, and the wheel arch bolts/bolts to fender but you can leave the three front bolts to rad support--.
You can then see what is happening. I will say that if the air passages are clear and the thermostat is working, an original fan will work fine. I've seen motor fans chewed into pieces from mice. I removed debris from every truck I've parted out~~ If you open the passenger side vent all the way and stick you hand thru the hole and down into the outer air box, you may find leaves, rags, dead mice, snake, tools, etc. Yep, found them all. You can also find all of the above behind the blower motor or up against the heater coil itself. Bet you find junk behind the fan~~~~
Huck is offline   Reply With Quote
