Old 04-18-2014, 12:22 AM   #151
mcbassin
Still Learning
mcbassin's Avatar
Re: '72 Drop member... "Betty"
Originally Posted by olrosa View Post
Cab progress. (Before high hump) Lmfao
Nice score on the high hump. If you haven't bought your carpet yet, check with Kyle at Laidbackrecreations I bought mine from him, best deal and high end quality.
Old 04-18-2014, 03:21 AM   #152
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Cab is looking great....
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-18-2014, 10:10 AM   #153
olrosa
olrosa's Avatar
Originally Posted by screaminchevypickup View Post
Have you put a high hump in the cab yet?
You saved my but screaminchevy, thank you!
I ordered it from Trim Parts. Sometimes I can get pretty good deal through my chevy dealership
Thank you, glad you like it. Just wish I had more time to work on it... getting there tho
olrosa is offline   Reply With Quote
Old 04-19-2014, 03:38 PM   #154
olrosa
olrosa's Avatar
Cab just about ready for chassis. Going to start fitting sloshtubz this week. So stoked to start putting back together.
Old 04-19-2014, 07:15 PM   #155
jmmy1968
What's the paint code on the red interior paint?
jmmy1968 is offline   Reply With Quote
Old 04-19-2014, 07:31 PM   #156
olrosa
olrosa's Avatar
We custom tinted it to match the red on the seat
Old 04-21-2014, 10:45 PM   #157
olrosa
olrosa's Avatar
Sprayed some reflex bedliner under the sloshtubz. I didn't want any rocks to star the gel coat if the tire threw a rock.
Mike losh did Awsome on these. I love em. Thank god he went through all the trouble to make these. Only saves a guy like 6 months of labor!
Old 04-21-2014, 10:55 PM   #158
olrosa
olrosa's Avatar
Starting to get some assembly done. It's kinda hard to see but I duplicated the dimples from the factory welds on the panels that were welded in on firewall. I want it to look like GM put it there
Old 04-22-2014, 01:24 AM   #159
eightbanger
454 MAKES IT ROAR
The devil is in the detail.
Nigel.
No more pain.
Old 04-22-2014, 08:22 AM   #160
mcbassin
Still Learning
mcbassin's Avatar
Very clean work Seth. Looks great.
Old 04-22-2014, 09:00 AM   #161
builtbyKane
builtbyKane's Avatar
Truck is coming together nicely. Its starting to get me motivated to get mine on the road
builtbyKane is offline   Reply With Quote
Old 04-22-2014, 09:43 AM   #162
olrosa
olrosa's Avatar
Thanks guys, glad you like it. Should hav sloshtubz mocked up today. Maybe cab can go on chasis next week!
Old 04-23-2014, 09:48 AM   #163
olrosa
olrosa's Avatar
Sloshtubz all mocked up. Time to paint the inner front clip
Old 04-23-2014, 09:50 AM   #164
olrosa
olrosa's Avatar
Willie put in some gold grade 8 bolts to match the frame bolts. Looks really good
Old 04-23-2014, 10:12 AM   #165
Bennett68C10
Bennett68C10's Avatar
Nice job, love all the details
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-24-2014, 09:25 AM   #166
olrosa
olrosa's Avatar
Front setup
Old 04-24-2014, 09:42 AM   #167
SCOTI
SCOTI's Avatar
Have you mocked-up your steering linkage? If I remember correctly, the OE driver side ram horn interferes w/the shaft for the R&P. I had to use Speedways version (they're tighter to the block vs the OE type units).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-24-2014, 09:59 AM   #168
Hart_Rod
Hart_Rod's Avatar
Looks good. I would remove the panhard bar mount on the rear end. That will give you clearance if you decide to run a full exhaust.
Hart_Rod is offline   Reply With Quote
Old 04-24-2014, 05:44 PM   #169
olrosa
olrosa's Avatar
Well that would be par for the course. I will get motor set in soon and we'll see. I really wanted to keep stock-ish look. I guess speedway will work if it hits. Thanks for the heads up SCOTI
Old 04-24-2014, 05:46 PM   #170
olrosa
olrosa's Avatar
HART_ROD, looks like I have room. We will see soon enough I guess. Thank you for the advise!
Old 04-24-2014, 06:00 PM   #171
SCOTI
SCOTI's Avatar
Yep.... same here. I wanted the OE look & purchased some new Dorman manifolds w/the intent of cutting them down & slicking the up a bit. Glad I checked fit 1st before doing all that work.
The Speedways tuck tighter to the block vs the OE ramhorns which allowed enough clearance for a shaft to squeeze in there.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-24-2014, 08:23 PM   #172
GSFMECH
On the road
GSFMECH's Avatar
It's coming along nicely, you have me thinking about making some changes to my truck.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 04-24-2014, 08:48 PM   #173
olrosa
olrosa's Avatar
Thank you! I dig your truck it's super clean!
Old 04-24-2014, 11:35 PM   #174
GSFMECH
On the road
GSFMECH's Avatar
Thanks!!
Mike
Old 04-25-2014, 10:12 PM   #175
olrosa
olrosa's Avatar
Carpet came in today from TrimParts! Really good quality. I am super happy with the quality. Highly recommend it.
Good call knomadd and screaminchevypickup
