Old 01-03-2004, 04:57 PM   #1
k5hart
k5hart's Avatar
Help - Gas Tank Install
Heeellllpppp. Now that I got the hose problem figured out I am trying to get this new gas tank installed in my blazer. I ordered a steel tank kit from Early Classics and I just realized I have two different straps.
I am going to call them Monday, but does anyone have some pictures of what the straps should look like. I may have to make one so I can get the truck out of the garage. I have another project that may come Wednesday and I need to have the garage empty badddd!
Also does anyone have some pictures of a stock tank installed, from passenger and driver side. The old tank was custom built so I have none of the old mounting hardware and nothing to go by to make sure I have it in correct. I know that there was supposed to be some kind of guide blocks that sat between the frame and the tank flange. Any idea where to get these and do I really need them?
Sorry for all the questions. Just want to do this right the first time. Thanks for all the help.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 01-03-2004, 05:29 PM   #2
k5hart
k5hart's Avatar
Here are some pictures to show what I am talking about.
1
Old 01-03-2004, 05:30 PM   #3
k5hart
k5hart's Avatar
2
Old 01-03-2004, 05:31 PM   #4
k5hart
k5hart's Avatar
3
Old 01-04-2004, 01:01 AM   #5
classicchev
classicchev's Avatar
I believe you want to use the second one. Mine only bolts on on one side, the other slides in a hole in the frame. Im sure you can use bolts on both sides. Good luck Darren
classicchev is offline   Reply With Quote
Old 01-04-2004, 03:41 PM   #6
k5hart
k5hart's Avatar
Thanks Darren. After calming down and taking a second look I realized that I could reverse the bend in the second one and they would both match. Carefully did this using the tank as a form and got the tank in last night. Started it up this morning without a problem. Whew. Glad this job is over.
I still would like some input on the tank guides I mentioned in the first post. Anyone know about these?
Thanks everyone for the help. I also put in an Early Classics hidden hitch and have some good pictures of the install if anyone needs them.
Later, Jason
