Old 02-01-2014, 10:09 PM   #151
sqrlnts
Re: My 1959 Fleetside Build
Originally Posted by pbeguy View Post
My wife told me the first step was admitting it...
My name is Larry and I am a hoarder.... Ha-Ha!!!
3 short fleets Larry, really? What the hell will she call you when you get the fourth one?
sqrlnts is offline   Reply With Quote
Old 02-17-2014, 09:59 AM   #152
pbeguy
pbeguy's Avatar
Got some finish work done this weekend. Doors and fenders are final primed and guide coated.
pbeguy is offline   Reply With Quote
Old 02-17-2014, 11:54 AM   #153
Spblack
Spblack's Avatar
its about time you start messing with this again, lol
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 02-17-2014, 12:19 PM   #154
Kim57
Kim57's Avatar
They look real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-18-2014, 08:51 PM   #155
pbeguy
pbeguy's Avatar
A couple of pics.
1. For the clinically insane, here is how my rear tire fits into my new bedside notch.
2. Had to cut off my entire bridge and raise it it a bit. My bags were to tall.
3. I am toying with the idea of attaching a 3.5" angle on the bottom of my frame
to keep from tearing my truck body on speed bumps and other nasty things.
The body sits right at 3.5" below the frame.
Old 02-18-2014, 11:30 PM   #156
Kim57
Kim57's Avatar
That looks sweet.
Kim
My build thread
Old 02-20-2014, 11:57 PM   #157
pbeguy
pbeguy's Avatar
Got a door hung. I picked up some new hinges on eBay a while back. They worked great. I used all new bolts. I am going to wait till the cab is mounted for final adjustments.
Old 03-10-2014, 09:54 PM   #158
pbeguy
pbeguy's Avatar
Well..
I finally committed to a 4-link and welded it up. I converted some parts I had been saving and fabbed it all up. I get 8 full inches of lift front and back. It is triangulated so I may not run a panhard bar but I will weld the mounts on anyway.
I can say ...finally... the bags are done except for the pump, tank and lines.
spblack came by this weekend and gave me some inspiration. He is kicking butt on his.
Old 03-11-2014, 10:23 AM   #159
Kim57
Kim57's Avatar
Looks good.
A pan-hard bar may want to bind using it on a triangulated four link as it will want to move the rear slightly from side to side as it moves up and down through its arc.
Kim
My build thread
Old 03-12-2014, 11:34 PM   #160
pbeguy
pbeguy's Avatar
Who replaces the emergency brake pad and the backing plates on a rear end re-do??
My wife says "Crazy people do, that's who"
I want as much slow as I have go.
Old 03-18-2014, 11:21 PM   #161
pbeguy
pbeguy's Avatar
Ordered my drive shaft from Southern Speed. Brake lines and fuel line from Ebay.
A minor but significant step was getting it rolled out of the shop for the first time in a Looooong time. Aired up and holding on its own. Yee-Haw!!
It has tons of clearance.
Old 03-18-2014, 11:29 PM   #162
Kim57
Kim57's Avatar
That's going to look real sweet when done.
Kim
My build thread
Old 03-20-2014, 09:10 PM   #163
Painter D
Painter D's Avatar
Nice work so far
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 03-24-2014, 11:00 PM   #164
pbeguy
pbeguy's Avatar
Working on making the front tires fit and still have some inner fender.
I feel like a surgeon.
Old 03-25-2014, 10:13 AM   #165
Kim57
Kim57's Avatar
That's pretty tight.
Kim
My build thread
Old 03-29-2014, 10:43 PM   #166
pbeguy
pbeguy's Avatar
Worked on brake lines, fuel lines, air bag lines and front suspension. Tightened every nut and bolt in the front and finished the center link and tie rods. I forgot how much I hated fitting brake lines.
Also got my temporary plate. Waiting on the real one.
Old 03-30-2014, 11:40 AM   #167
Kim57
Kim57's Avatar
Cool plate.
Kim
My build thread
Old 03-30-2014, 08:43 PM   #168
OrrieG
OrrieG's Avatar
Isn't that a weird Al song based on Madonna???? Nice Plate
Old 03-30-2014, 09:02 PM   #169
Rednek13x
Rednek13x's Avatar
looking great!
Rednek13x is offline   Reply With Quote
Old 03-30-2014, 10:56 PM   #170
pbeguy
pbeguy's Avatar
Got the front end bolted on properly. I am cutting a few corners in an effort to get it ready for the upcoming show. I am using some extra under hood panels I had laying around. Modified the headers and installed them. It has been sitting for 2 days with the air bags inflated checking for leaks.
I know I will regret it later not taking the time to finish it up right, but I am tired of not being able to drive it and work the bugs out.
I have to decide tomorrow if I am going to use a firewall or under cab brake system and just go ahead and put it on.
Old 03-31-2014, 10:39 AM   #171
Kim57
Kim57's Avatar
Looking good.
I know what you mean about wanting to get it on the road. I go through the same thing with mine.
Kim
My build thread
Old 03-31-2014, 01:33 PM   #172
_Ogre
_Ogre's Avatar
under cab won't mess up that pretty firewall
this looks good; your a master surgeon
shop air compressor timer
Old 04-22-2014, 10:23 PM   #173
pbeguy
pbeguy's Avatar
Still working hard on the truck.
I had to roll it out of the shop to get the Impala ready to go to its new home in Vanderhoof, British Columbia. If it was a two door I would not part with it.
Got the air tank installed behind the seat and the lines run out of sight enough for me. It goes up and down fine.
Got a great deal on a new door and put it on. Started wiring it up.
I am learning a whole new level on patience on this one.
Old 04-22-2014, 10:45 PM   #174
Spblack
Spblack's Avatar
looking good larry.
My builds:
Old 04-22-2014, 11:13 PM   #175
pbeguy
pbeguy's Avatar
Originally Posted by Spblack View Post
looking good larry.
I keep expecting you to drive up one day in yours.
Lets do a convoy to Hoedown on May 24th in Hempstead.
