04-20-2014, 05:51 PM | #1 |
How do I wire the check engine light?
Hey guys got the truck fired last night and it sounds awesome. I have auto meter gauges with a billet bezel. I purchased some led lights from brothers to use as the blinkers and the engine light. Each light has a black and white wire. The blinker lights work fine. I have a wire from the harness for the engine light hooked to the black wire and the white wire is hooked to the lighting wire. Did have a couple codes but the light did not come on. Should the white wire be hooked to a power source instead. Pleases advise thank you
04-20-2014, 05:59 PM | #2 |
Re: How do I wire the check engine light?
Ignition power on the white wire. The PCM sends a ground to light the SES light.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-20-2014, 06:37 PM | #3 | |
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
04-20-2014, 06:41 PM | #4 |
Old member
I have the same question. The check engine light should be hooked to a switch on hot wire then go to computer and it will send it to ground if there is a reason for it. Correct?
If so I have mine hooked up backwards also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-21-2014, 12:23 AM | #5 | |
04-21-2014, 12:25 AM | #6 |
Also badazz...YouTube is about the easiest from my experience, I just hooked up my CEL, it was pretty easy...it's on my build...well the location anyways
04-21-2014, 08:06 PM | #7 |
Ok, so I'm the 3rd guy that has it hooked up wrong. Mines just a two prong light from the parts store, has the white wire from PCM on one, and I grounded the other. So I just need to remove the ground, and run ignition source to it? Luckily I have never brought up any codes, but always wandered if the light was hooked up right.
04-21-2014, 08:41 PM | #8 | |
04-21-2014, 08:42 PM | #9 |
Did you get it from orileys? If it's the same one I got the white wire is negative and the black is ground
04-21-2014, 08:57 PM | #10 |
Got it at Baxters, and it doesn't have wires, just male ended prongs. But she works now for the first time in a year. Thanks Ls1nova71
04-21-2014, 08:59 PM | #11 |
Oh gotcha, I'm used to black being ground, mine was opposite, but it came on today for the 02, holy crap it's bright
04-21-2014, 09:01 PM | #12 |
So I was wrong I have the white wire going to the engine light wire and black to lighting. I just connected the black wire to the ignition source and left the white wire hooked to the pcm wire. The light is not coming on when I turn the key to the on position. If the light only has two wires does it matter what color I use? Should the light come on in the on position?
04-21-2014, 09:26 PM | #13 | |
04-22-2014, 10:48 AM | #14 | |
04-22-2014, 11:01 PM | #15 |
Old member
1moretoy,
glad you got it figured out. I went outside tonight and rewired mine. It's also working but I have one more question for everyone. Mine is a LED light and it lights up fine as you can see in the picture. The only thing is after I crank the truck up it flickers not very bright like the picture but really dim. What do you think it could be. Oh the computer isn't hard mounted so it's not grounded through the frame are cab back to the battery. I don't know if that would make a differance are not.
04-23-2014, 12:15 AM | #16 |
LEDs will glow slightly when ever the key is on, that's normal. It has something to do with the circuitry in the PCM and the fact that LEDs take very little voltage to light up. If you switch to a regular light bulb it won't do that.
04-23-2014, 09:15 AM | #17 |
Old member
OK thanks, I was thinking something was going on with the ECU.
