Old 04-19-2014, 09:44 PM   #1
J48chevy
J48chevy's Avatar
Rear leaf kit
Has anyone used the kit from CPP? Looks like a great kit that will fit the 3" explorer rear end. This is what I am leaning towards but wanted to see if anyone has purchased this.
http://www.classicperform.com/Store/...ks/4754RLK.htm
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 04-21-2014, 09:38 AM   #2
whitedog76
Re: Rear leaf kit
I don't know how expensive the 8.8 swap kit is, but here is an alternative.
http://www.ruffstuffspecialties.com/...g/88SS-31.html
The Ford Ranger rear leaves have similar arch to what you need. Another option is the Chevy Colorado leaf springs.
http://www.sdtrucksprings.com/index....oducts_id=7712
http://www.sdtrucksprings.com/index....o&products_id=
I also like the Ranger spring mounts and shackle setup.
http://www.sdtrucksprings.com/index....oducts_id=9660
http://www.sdtrucksprings.com/index....oducts_id=9417
whitedog76 is offline   Reply With Quote
Old 04-21-2014, 04:15 PM   #3
pgf545
pgf545's Avatar
Re: Rear leaf kit
I used that kit and it seemed to work ok. What are needing to know?
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 04-21-2014, 04:34 PM   #4
J48chevy
J48chevy's Avatar
Re: Rear leaf kit
Just wanted to know if they are a good kit. Both CCP and Speedway have good prices. I know I need the 3.25 u-bolts but the rest is useable.
Bernie
Old 04-21-2014, 05:37 PM   #5
pgf545
pgf545's Avatar
Re: Rear leaf kit
I don't think our came from CPP but it the same kit. I can't remember where we got ours.....It's pretty cool because it bolts right up to the existing hole in the frame if I remember right. You do have to remove the original hangers that are riveted to the frame. I think there might be some pictures in my build thread, if not let me know and I will see if I have any on my computer at home.
Bernie
Old 04-22-2014, 12:06 PM   #6
solidaxel
solidaxel's Avatar
Re: Rear leaf kit
THANKS, Booked Marked this page !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-23-2014, 03:13 PM   #7
55dude
55dude's Avatar
Re: Rear leaf kit
check out the 67-72 chevy truck setup that use trailing arms with coil springs, they refer to it as NASCAR style. i met no less than a dozen builders when i lived in socal that used that setup, easy to add air bags and rode great.
55dude is offline   Reply With Quote
