Old 04-23-2014, 10:35 PM   #11
bovey
bovey's Avatar
Re: Targa Truck '71 GMC build - The first truck in Targa Newfoundland
Originally Posted by 1970 CST Short Wide View Post
Thanks I figure I'll have to modify, Its always good to see how others did it
Okay, here is my bracket in all of it's surface rusted glory. Your question totally reminded me that I need to take this off and finish it, as it actually works.
I use a Lokar throttle cable. I had planned on using the stock one, but it kept hanging up due to the stock cable design. I highly recommend buying a aftermarket cable if you do this.
Here is a close up of the bracket. I will be trimming off the holes for the springs as they are too close to my front spring mount to work. I have a discrete bracket mounted on a intake bolt that provides the right stretch. FYI - the throttle return springs are hidden behind the fuel rail.
NOTE: this bracket has a lip the puts pressure on the back of the carb mounting tab so it does not move when you jump on the throttle.
I like my parts simple and small. I had an Edelbrock bracket, but it was like the Eiffel tower coming off my intake. Worked fine, hated the look of it.
When I take it off to finish/paint it. I'll post a photo of the underside.
Targa Truck The first truck in Targa Newfoundland.
https://www.facebook.com/targatruck
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=625874
Action Video: https://www.youtube.com/watch?v=ru3i7lPP5EA
bovey is offline   Reply With Quote
autocross, race, track, truck
