Old 04-24-2014, 02:29 PM   #26
theredmeadow
Re: truck doesn't start
I hooked up a jumper wire from the + of the coil to the battery and the truck jumped.
theredmeadow is offline   Reply With Quote
Old 04-24-2014, 04:55 PM   #27
theredmeadow
I got it running guys! So you guys were right, points were dirty. It had gummy oily gunk on it. I wiped it as much as I could with a paper towel and it started up! So whats the best way to clean it?
p.s.
I also found the small arm that connects the choke!
Old 04-24-2014, 05:31 PM   #28
theredmeadow
Originally Posted by litew8 View Post
Bruce88 wrote up some info.
If applicable:
Replacing Contact Breaker Points - YouTube
is there a way to pull off the mechanical springs part? if I can pull that off then I can clean it better.
Old 04-24-2014, 06:15 PM   #29
litew8
litew8's Avatar
good job
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 04-24-2014, 06:31 PM   #30
theredmeadow
good job
I think I didn't clean the points. What I cleaned was the motor shaft part that moves the point. However it looked like it wasn't even touching the point. Are those mechanical spring piece removable? If I can remove it I can see the points. As it stands now I can't see the points.
Old 04-24-2014, 06:36 PM   #31
litew8
litew8's Avatar
Did you do anything else before or during? You might be able to spray some contact cleaner in there. Something that leaves no residue and dries quickly. Try doing a google/youtube search for disassembly. It's been decades since I've had to service a distributor, so I'm not much help there. Does the truck run OK, GOOD? Did you hook that linkage back up? Did you rewire the 'de'-choke?
like
Old 04-24-2014, 09:31 PM   #32
theredmeadow
alright, yeah that was the points. I cleaned it more. I also reattached the choke arm. it starts right up like a champ! thanks guys! I knew you could solve it.
Old 04-24-2014, 10:02 PM   #33
litew8
litew8's Avatar
good job, again Now you'll know what to look for next time (and there will be a next time with them, only it may be they'll need replaced, so keep studying).
