Old 12-16-2003, 08:03 PM   #1
85gmcguy
Plays with trucks
85gmcguy's Avatar
Question A-frames vs spindles
I realize I'm probably covering old ground, but I'm fairly new here. How do lowered A-arms compare to lowering spindles/springs as far as ride quality and handling? I'm planning a 3/5 drop for my 85 GMC short bed. Rear will be C-notch and flip kit, but I'm still debating on method for the front. I know the A-arms are more expensive, are they worth it?
85gmcguy is offline   Reply With Quote
Old 12-16-2003, 08:46 PM   #2
fastbagged68
fastbagged68's Avatar
dropping it with lower control arms is not as good as spindles. The control arms cups hang lower to get you your drop. I would recommend spindles and springs. or just a 3 inch drop spindle.
fastbagged68 is offline   Reply With Quote
Old 01-03-2004, 09:38 PM   #3
85gmcguy
Plays with trucks
85gmcguy's Avatar
Would one handle better than the other, assuming the same tire and shock combination?
Gary
My Dad's Old Truck
1985
Old 01-03-2004, 10:25 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
in my experience, there is no difference in handling, but the lower control arms are already hanging lower than any other point on the truck- and using dropped LCA'a only adds to the problem. I would definiately use the 3" spindles.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
