![]() Join Date: Mar 2014
454 seems to high
I got some factory bbc stands but my engine seems to be too high in the front.i haven't fixed my crossmember for the th400 but I cant jack it up any higher in the back due to the transmission hitting the body.does the motor need to be level?
Re: 454 seems to high
Doesn't seem to be that high. If i recall, they don't sit level. Here is a picture of my 402/700R4, obviously the 700R4 is not the same length, but close. I'm sure it's fine.
Mines not level either. Has a slight tilt to the firewall.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Make the carb mount level. Adjust it at the tranny mount. They normally tilt back. About 3 degrees downward.
![]() Join Date: Jun 2012
Mine ended up at around 4 1/2 degrees. I will adjust the pinion to make it work
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
The only way I can get the carb plate level is to change the front stands.I can jack the rear of the transmission up till it hits the truck body an it's still not level.the way it's sitting now I have just enough clearance between the transmission an the body.
Watch out for your cornhole !
![]() Join Date: Jun 2003
How tired are your body mounts ?
I put a 454 and TH400 in my shortbed a few years ago (low hump cab) using those same factory mounts you're using. The trans hit the body until I swapped the old saggy cab mount biscuits for new ones. Then it cleared plenty. It goes without saying that you have the wrong trans crossmember and mount in there currently. I assume that's what you're leading to when you say you havent been able to do that part yet.
[QUOTE=Tx Firefighter;6647370]How tired are your body mounts ?
I put a 454 and TH400 in my shortbed a few years ago (low hump cab) using those same factory mounts you're using. The trans hit the body until I swapped the old saggy cab mount biscuits for new ones. Then it cleared plenty. It goes without saying that you have the wrong trans crossmember and mount in there currently. I assume that's what you're leading to when you say you havent been able to do that part yet.[/QUOTE I haven't checked the body mounts.I found a post where someone used a crossmember out of a 84 suburban an that's what I was trying since I had one available.it looks like I'll be fabricating my own.I was concerned about the engine angle because the transmission can't come up unless it's tired body mounts like you said. |
I didn't take a ton of pictures back then like I do now (pre camera phone days)
