Bed Replacement Question
Hey Fellas, After wearing out the original bed of my '84 3/4 ton, I replaced it with one off of a '75 half ton. Having used it for the last few months it is quite apparent that the one I just put on is not as stout as the one I wore out. Were the '70's models a thinner gauged metal, or did you get a better body with a 3/4 ton? Any insights?
Re: Bed Replacement Question
No insights on that? Maybe I am mistaken. Either way, I will put a spray in liner and build an angle iron frame to stiffen it up. Any other ideas?
RR
Should be the same metal, but if the bed has replacement panels or floors, the replacment metal could be thinner. The only significant changes that I can recall are the fuel cap vs door and tailgates.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB 1987 GMC V3500 Dump, 6.2L diesel, TH400 1983 GMC K2500 - awaiting its restoration and Cummins swap. |
That seems to be the consensus from all the people I am talking to. Thanks.
Same bed was used on all models (ie, a 1/2 ton got the same bed as a 1 ton).
By the way - on the 2014 and beyond K2XX pickup box, there is a HD box released for 3/4 ton and 1 ton. It gets a couple additional braces under the rear sills and some doublers at the attaching points. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
