Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-24-2014, 09:11 PM   #1
Theoriginalsilverado
Question Favorite Tools
Hey guys!
I live in Newfoundland, and getting a tool as I need it isn't as simple as running to the local store- There is none. This weekend I'm making a run to town, and I plan on picking up as much tools as I think will come in handy, in particular anything to help me sand my chassis.
My question for you is what are your favorite tools, for any job in any step of restoration/working on your truck? Cheap or expensive!
Also what's your preferred degreaser, primer, paint, etc.?
I guess the main question is what do you think every garage should have? ( Other than the basic wrenches screw drivers hammers, etc.)
Thanks for the input. I'll let you know what I grab this weekend!
If It runs like a Chevy, it probably is!
Theoriginalsilverado is offline   Reply With Quote
Old 02-24-2014, 11:02 PM   #2
truckdude239
truckdude239's Avatar
Re: Favorite Tools
3/8" 14.4 volt impact and 18 volt 1/2" impact gun
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 02-25-2014, 08:42 AM   #3
superwade57
Re: Favorite Tools
A good cable operated hose clamp pliers but that's more for.the new stuff. Use one once you'll never live with out it again.
superwade57 is offline   Reply With Quote
Old 02-25-2014, 10:54 AM   #4
Kim57
Kim57's Avatar
Re: Favorite Tools
For cleaning my frame I used my 4-1/2" angle grinder with wire wheels attached to it.
I used the cup and flat types.
They do wear out so I would have a couple of each if it's a long drive to town.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-25-2014, 05:40 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Favorite Tools
I'd say the small cut off tool and a air chisel ,need a compressor tho
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-11-2014, 02:32 AM   #6
Kaysen
Re: Favorite Tools
Never heard of such, so I looked them up. Yep, definitely gonna be buying a pair of those.
Kaysen is offline   Reply With Quote
Old 03-11-2014, 09:20 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Favorite Tools
I have a lot of tools, some very expensive, but my favorite is this set of SnapOn flare nut/open end wrenches. They are kind of mis-matched because I collected them on eBay over time as I found good deals. After a career of using lesser flare nut wrenches, the SnapOns are fantastic. Fittings that other brands would strip, the SnapOn loosens up without damage.
My favorite 1/4" drive ratchet. It's an antique, but I like it better than my new SnapOn Dual 80s. This was a broken swap meet find that I paid a buck for. Then I finally found a rebuild kit for it. I'm into it for about 10 bucks total. It's somewhere in the 60s era vintage and works smoother than any ratchet I've ever used.
And I'm currently collecting SnapOn "hi performance" metric deep offset box end wrenches. These are not very common so the collection is slow going. I'll get there eventually.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-16-2014, 07:31 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
Re: Favorite Tools
I'm not sure if Josh has enough bandwidth for me to list mine. There's about $30K worth of "favorites" in my box. But if I had to slice a couple off the top of the list, it would be my Ingersol Rand 2112 3/8" impact and Power Probe III
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 03-16-2014, 01:55 PM   #9
dieseldawg142
dieseldawg142's Avatar
Re: Favorite Tools
not my favorite tool, in fact i dread pulling it out, but has saved the day many times, even when my Ingersol Rand 600 impact wont cut it.
this wonder tool?-craftsman 1/2" 24" long breaker bar.
working on a chassis you will need it!
dieseldawg142 is offline   Reply With Quote
Old 04-03-2014, 09:11 AM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Favorite Tools
[QUOTE=Tx Firefighter; my favorite is this set of SnapOn flare nut/open end wrenches. After a career of using lesser flare nut wrenches, the SnapOns are fantastic. Fittings that other brands would strip, the SnapOn loosens up without damage.[/QUOTE]
I learned this lesson long ago. Money very well spent.
Tom Vogel is offline   Reply With Quote
Old 04-03-2014, 12:19 PM   #11
ERASER5
ERASER5's Avatar
Re: Favorite Tools
I'll second on the air hammer. After beating on a hub assembly for 10 minutes with a BFG, the little air hammer popped the hub out in 20 seconds.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-03-2014, 12:43 PM   #12
Daddy'O
Daddy'O's Avatar
Re: Favorite Tools
My Refrigerator - keeps my favorite beverages nice and cold...
Seriously - I love my Power Probe III.
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 04-03-2014, 11:23 PM   #13
GM-power
GM-power's Avatar
Re: Favorite Tools
A favorite tool boy thats hard!!! Just for makin life easy I like my wobble impact sockets! Got matco adv deep and snap-on shorts.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 04-03-2014, 11:37 PM   #14
magicoolbus
magicoolbus's Avatar
Re: Favorite Tools
Love my Simpson 260 8P.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 04-05-2014, 11:30 AM   #15
First c10
First c10's Avatar
Re: Favorite Tools
BFH
Or LFH for the smaller jobs
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-05-2014, 01:30 PM   #16
BarryB
BarryB's Avatar
Re: Favorite Tools
I have a bunch of "favorite" tools, each has there purpose they were made for. I just recently purchased a tubing flaring tool. That is AWESOME! from either Eastwood or inline tube. I bought mine from the inline tube ebay store.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 04-10-2014, 03:09 AM   #17
familyfast64
familyfast64's Avatar
Re: Favorite Tools
My new favorite tool is the beed roller. My old favorite was my first mig welder. Tool I absolutely couldn't do without... Air compressor worthy of cfm
Live and let live
familyfast64 is offline   Reply With Quote
Old 04-23-2014, 09:34 AM   #18
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Favorite Tools
[QUOTE= I just recently purchased a tubing flaring tool. That is AWESOME! from either Eastwood or inline tube. I bought mine from the inline tube ebay store.[/QUOTE]
I have one as well. Excellent tool.
Old 04-24-2014, 09:11 PM   #19
glider_6969
Re: Favorite Tools
Hi Guys, thought you all would get a good laugh,
Here is a collection of definitions and uses you may find helpful.
TOOLS EXPLAINED
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh ****'
SKIL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50-cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Son of a ***** TOOL:
Any handy tool that you grab and throw across the garage while yelling 'Son of a *****' at the top of your lungs. It is also, most often, the next tool that you will need
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline   Reply With Quote
Old 04-27-2014, 01:04 AM   #20
In The Ten Ring
Re: Favorite Tools
OMGosh that was funny!
I haven't done too much to my truck but here is what I have used or plan to use.
1). Socket set, 3/8" drive.
2). Combination wrench set.
3). Ball peen hammer.
4). Screw driver set.
5). 2.5 ton wheeled floor jack.
6). Wood blocks (lots)
7). 3 ton jack stands (2 of).
8). Brake drum tool set.
9). Shop towels
10). Powered drill with wire brush.
11). Dremel tool and cutting wheels and grinding bits.
12). Flashlight.
13). Double flare kit for new fuel lines.
14). Bench vise.
15). Center punch.
16). Safety glasses and face masks.
17). 4-way lug wrench.
18). ZEP 45 (break free).
19). Drip pan for catching motor oil and antifreeze.
20). Drill bits & drill.
21). Reverse drill bits.
22). Extractor set for removing broken bolts.
*I'm sure I am missing something but that's about all I've used.
In The Ten Ring is offline   Reply With Quote
Old 04-27-2014, 01:05 AM   #21
In The Ten Ring
Re: Favorite Tools
I'd like to see that thing in action! I am about to start on my new fuel lines and I bought the tool that goes in a bench vise. The one I bought is from Craftsman.
Old 04-28-2014, 01:00 AM   #22
In The Ten Ring
Re: Favorite Tools
Forgot a few! Will edit.
cheap, favorite, tools
