wheel bearing Grease Seal: Flush or not?
Re: wheel bearing Grease Seal: Flush or not?
Doesn't look seated to me.
You could always pull the other side to compare, but I'm pretty sure its not seated. |
I always took a 2x4 and tapped that puppy flush with the hub.
May be just the camera angle but it looks like it's driven in farther on the right than the left...
Josh '70 Custom Camper / 20 |
Old member
Seal should be flush with back of hub. It's not seated yet.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Should be flush.
Your seal is not seated. It looks like its right up against the inner bearing. Is that bearing preventing it from going further into the hub? Did you do anything else like replace the inner bearing and race? If the bearings where replaced did you compare them to the old bearings and did they match? It's very common to receive incorrect parts from suppliers. Is the bearing race fully seated in the hub? Is the race cockeyed in the hub preventing it from fully seating? Is there any debris or obstruction between the race and hub seating surface which would prevent the race from seating properly? Something appears to definitely be up there with the seal and/or bearing and needs to be looked into. Please keep us posted on the resolution.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72 1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code" 1970 Mercury Cougar "Eliminator" 351C-4V C6 1972 Ford Ranchero GT 351C-2V C6 1974 Honda XL-350 Member of the "6 C's and a D" 1-Ton Fun Club! |
71 Dually-- Im going to pull the other one apart since it only has the Bearing race installed currently and re-verify everything (Size/shape/height).. Ive checked them once..but something isnt right.
The other bearing seal was installed and removed and ther is evidence that its bottoming out against the new race..im perplexed why these dont drop right in since they are they same height as the original.. Ill also ck to makse sure im getting the new race all the way down (best i can tell it is) |
You should be able to look in from the opposite side and see if the race is up against the stop. If it is, you probably have the wrong bearings. Looks like the inner race isn't seated all the way, causing the seal to stick up.
