Old 04-27-2014, 10:27 PM   #1
75gmc454
75gmc454's Avatar
Found a 66
I mostly spend time on the 73-87 forum, but I have known about this truck for a while and I finally decided to buy it. It is not a custom cab, but it has the big rear window, 283, powerglide, and air cond. The truck has been sitting for a LONG time, but I did not want it to go to the crusher. Here are a few pics.
75gmc454 is offline   Reply With Quote
Old 04-27-2014, 10:32 PM   #2
rickywideglide
rickywideglide's Avatar
Re: Found a 66
looks pretty solid,what are your plans
rickywideglide is offline   Reply With Quote
Old 04-27-2014, 10:33 PM   #3
DPowers
One foot in front of the other
DPowers's Avatar
Re: Found a 66
Cool- what's the plan for it?
DPowers is offline   Reply With Quote
Old 04-27-2014, 10:43 PM   #4
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: Found a 66
Great Start of a BBW
Sweet Find
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 04-28-2014, 07:31 AM   #5
PGSigns
PGSigns's Avatar
Re: Found a 66
Good looking truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-28-2014, 07:57 AM   #6
Clyde65
Clyde65's Avatar
Re: Found a 66
Cool! I havent seen many Steppers that have the side molding before. Great find!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-28-2014, 09:36 AM   #7
Mathew21
Mathew21's Avatar
Re: Found a 66
Nice find, Congrats!
Mathew21 is offline   Reply With Quote
Old 04-28-2014, 09:50 AM   #8
65Gregg
65Gregg's Avatar
Re: Found a 66
That's the first thing that jumped out at me. Nice truck, time to get started!!!
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 04-28-2014, 10:44 AM   #9
TJ's Chevy
TJ's Chevy's Avatar
Re: Found a 66
Cool truck! Looks to me like it originally was a fleetside and was turned to a stepper...or perhaps someone just put the custom fleetside moldings on later.
Old 04-28-2014, 10:52 AM   #10
1963c-10
1963c-10's Avatar
Re: Found a 66
Looks to have a fleetside rear bumper....the stepside bed may have been added.
Nice project though...and more pics!!!
1964 Short bed trailer
Old 04-28-2014, 07:25 PM   #11
62 Barnfind
62 Barnfind's Avatar
Re: Found a 66
Good score! Can't wait to see what you are going to do with it.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 04-28-2014, 09:17 PM   #12
75gmc454
75gmc454's Avatar
Re: Found a 66
Thanks guys. I am going to get it running now. It spins over, but it is not firing. I probably need to clean the points so it will fire.
I think the truck was a fleetside also. The bed looks like it was originally a different color from the rest of the truck. Is there any way to tell without actually having the model number?
Old 04-28-2014, 09:44 PM   #13
62 Barnfind
Re: Found a 66
Mine did the same thing because it set for 30 years also. I put a new coil, cleaned points and plugs. It started right up. Here it is:
http://youtu.be/a95GCpWFEro
John Z
62 Barnfind
Old 04-29-2014, 11:51 AM   #14
rideblue00
rideblue00's Avatar
Re: Found a 66
Gotta love that 62 barnfind, no way a car today could sit for 30yrs and be able to start up with such minimal work.
rideblue00 is offline   Reply With Quote
Old 04-29-2014, 12:47 PM   #15
JWheeler331
JWheeler331's Avatar
Re: Found a 66
on the vin number if I remember right if the last two numbers are "04" is step side and "34" is Fleetside.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline   Reply With Quote
Old 04-29-2014, 01:04 PM   #16
1963c-10
1963c-10's Avatar
Re: Found a 66
Crawl under the truck and see if the bed mounting brackets have been moved. Or look in the bed if its wood and see where the bed bolts run through. You can use either bed on the same frame, just different mounting locations. Factory mounts were riveted in. So to swap the bed, they either moved the bed mounts or the mounting holes in the stepside bed to match the fleetside frame.
