Old 01-03-2004, 12:40 AM   #1
67gmcss
dumbest move of the day
Mayor of Stupidville here...I am trying to put power brakes on a manual truck. Found a set-up on a junked truck in a farmer's field about 3 hours from home. Took it all apart and went to Autozone for replacement booster since the other had been sitting in a field for 2+ years with no hood or anything over it. Get it home and now I don't know where the two support brackets that mount to it go on the firewall (one is round and fairly straight and the other is flatter and has sort of an "s" bend to it). The truck I am putting it on has no marks or anything to tell me where they should line up. I could try hit or miss, but would rather beg some of you guys for input. Does anyone happen to have a pic or something of the booster set-up mounted to a truck or the whole thing just lying on the ground or anything? I know, I know--next time take pix or at least have my five year old do a crayon drawing or something before I completely destroy something. Thanks in advance and if you ever pass through Stupidville just look me up.
67gmcss is offline   Reply With Quote
Old 01-03-2004, 12:50 AM   #2
rage'nrat638
rage'nrat638's Avatar
here
rage'nrat638 is offline   Reply With Quote
Old 01-03-2004, 12:54 AM   #3
67gmcss
thank you much....do you happen to have any of the rear side of it?...where it actually mounts to the firewall? if not, thanks anyway--this will definitely get me started. (and hopefully eventually stopped)...Yeah, bad brake pun, but it's late so maybe too many people won't see it anyway. thanks again.
Old 01-03-2004, 12:58 AM   #4
68 Suburban
68 Suburban's Avatar
mark, where are you hooking up for vacume?
68 Suburban is offline   Reply With Quote
Old 01-03-2004, 01:08 AM   #5
rage'nrat638
rear of carb chris....i will go take a pic. buddy
Old 01-03-2004, 01:16 AM   #6
rage'nrat638
1
Old 01-03-2004, 01:17 AM   #7
rage'nrat638
2
Old 01-03-2004, 01:20 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Mr Mayor, I have a booster on my garage floor if you need more specific pictures.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-03-2004, 02:44 AM   #9
67gmcss
firefighter---i think he's got me covered, but thank you anyway....
Old 01-03-2004, 03:20 AM   #10
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
Wrong! :p I seen it, I seen it!
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
Old 01-03-2004, 12:41 PM   #11
68 Suburban
I meant on the engine. It looks like the hose form the booster goes down to the bottom of the engine. thanks
Old 01-03-2004, 10:51 PM   #12
jhow66
jhow66's Avatar
braces
67gmcss these may help-sorry so dark could not get enough light under hood of bother-in-laws truck in my garage. (mine was outside).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-03-2004, 10:53 PM   #13
jhow66
jhow66's Avatar
braces
#2
Old 01-03-2004, 10:55 PM   #14
jhow66
jhow66's Avatar
braces
#3
Old 01-03-2004, 10:58 PM   #15
jhow66
jhow66's Avatar
braces
#4
Old 01-04-2004, 12:02 AM   #16
jorgensensc
jorgensensc's Avatar
Are those braces really needed? When I converted to power brakes I left mine off. I've still got them if that is a major wrong thing to do.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-04-2004, 01:24 AM   #17
Tx Firefighter
In my opinion (as well as the GM engineers) they are needed. The booster assembly is very heavy and sticks a long way out from the firewall. That's a lot of leverage trying to make cracks in your firewall.
Old 01-04-2004, 01:44 AM   #18
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I would be putting those brace's back on!!! There were none on my blazer when I bought it and the firewall was cracking around the mounting bolt's... Those bracket's are hard to find when ya need em..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-04-2004, 01:13 PM   #19
jhow66
jhow66's Avatar
Also will give you a much firmer petal feel--no firewall flex.
