04-29-2014, 06:29 PM | #1 |
remote doors
I have a 87 R10 with power door locks. I would like to add remotes. Anyone done this or can tell me best place to start?
THANKS! BW |
04-30-2014, 02:22 AM | #2 |
Re: remote doors
If you can wire it yourself http://www.avsontheweb.com/product.p...cat=500&page=1 and how to http://www.avsontheweb.com/REC4_MANUAL.pdf
04-30-2014, 06:22 PM | #3 |
Re: remote doors
just buy one of the kits and hook it up autoloc is one brand that makes them.
04-30-2014, 06:44 PM | #4 |
Re: remote doors
Pretty easy.. First you get an alarm or keyless entry system. Then the alarm will determine neg trigger or pos trigger. You. Will then use relays to change the polarity if needed. When i installed mine i just got an alarm and hooked up the negative triggers for the. Door locks. I. Used in wire splices, so no cut wires. Basic info ... I know, but very hard to explain i.... I will try to find some pics.
04-30-2014, 08:55 PM | #5 |
Re: remote doors
Much THANKS guys. Think I have it down.
BW |
05-01-2014, 02:33 AM | #6 |
Re: remote doors
Any key less entry or alarm will do,The reason i showed you the avs one is the remote looks better then most and has a sliding cover and you can change out the buttons to anything you want.
05-01-2014, 05:47 AM | #7 |
Old Heap Driver
Re: remote doors
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
