08-15-2013, 09:36 PM | #1 |
sder caps
SPIDER caps !I picked up some 5x5 spider caps and trim rings . I have to wait to do the front disc swap to run them but here is a sneak peek let me know what you think
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
08-15-2013, 09:54 PM | #2 |
Re: sder caps
Those are sweet!! Where did you find those centers?
................................____ ................._________l/___\____ .................|_/(0) ___ll____/(0)_l. The lower they are the longer they get! |
08-15-2013, 11:31 PM | #3 |
Re: sder caps
Hey Sal do they make them for 6 lugs?..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
08-15-2013, 11:44 PM | #4 |
Re: sder caps
I like it, great alternative to the dog dish.
08-16-2013, 12:12 AM | #5 |
Re: sder caps
If someone ever decides to start making them for 6 lug, they'll be rich!
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
08-16-2013, 12:44 AM | #6 |
Senior Enthusiast
Re: sder caps
I've loved spiders since they first appeared in the early 1960's. Glad to see them available in the 5x5 pattern. They were even included in some of the early model car kits, I believe mostly in the Johan models.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
08-16-2013, 01:45 AM | #7 | |||
Re: sder caps
Thanks for the comments
08-16-2013, 10:00 AM | #8 |
Re: sder caps
looks good
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-16-2013, 10:20 AM | #9 |
1962 C-10
Re: sder caps
Looks good Sal! Going to Summit Racing now...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
08-16-2013, 01:33 PM | #10 |
Re: sder caps
I remember something about 6 lug spider caps on this forum and found it....
need to see if member ol skool chevy will chime in or maybe contact the vendor..http://67-72chevytrucks.com/vboard/s...d.php?t=516941
05-01-2014, 04:34 PM | #11 |
Re: sder caps
Any update on this post? I ordered spiders for my 71 C10 and the caps do not fit over the front hubs. Vendor is telling me they are unavailable to fit over the hub. BTW Truck is a 5X5 disc brakes. Thanks for any help.
05-01-2014, 08:15 PM | #12 |
Senior Enthusiast
Re: sder caps
Is the problem the spider cap won't clear the dust cap, or is the base diameter too small to fit over the hub?
I had the dust cap problem when I was running the flat police caps on Corvette style rally wheels. I solved the dust cap problem by flattening the end of the dust cap with a big socket inside the dust cap, and pressed the end flat in a bench vise. I had to be careful trimming the cotter pin on the spindle nut so it wouldn't contact the inside of the dust cap, but it worked fine for years, and I got to run my police caps until I wanted something else.
05-01-2014, 09:09 PM | #13 |
Re: sder caps
It is the diameter. They go down about half way and the cone shape contacts the outer edge of the hub. I saw other members posting about using spider caps but have yet to see a set on a c10 disc brake...... Thanks for the reply.
