Stylin
complete front end suspension change out
ok i want to completly change out my front suspension upper and lower control arms included, the studs to mount the upper control arm to the frame also. what all would i need to gather? anyone got an est. of a price on all this? thx
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
Insert Witty Text Here
I am doing that right now. Inner and outer tie rod ends, upper and lower ball joints, pitman arm and idler arm, and new springs. I'm replacing it all with Moog parts. Just the parts and alignment, doing all the work myself except the alignment, is costing me about $550.
I could have saved myself a little money and bought cheaper parts from Auto Zone or a kit from performance suspension, but I want rubber parts, and I want good parts. I assume you mean you will keep the control arms and replace the bushings in them. I can't figure out why you would replace the control arms or studs... Slonaker |
Stylin
my control arms are off of a 77' 2500 gmc cause i bent the other ones. and the studs are worn so i thought id change them out while i was at it ya know.
Slonaker. i believe the stock set that PST sells is MOOG. Just my opinion, that is the easier way to go, you get everything. I bought the Poly kit a few years ago and the only thing was wrong was the sway bar bushings, that was my fault, i told them the wrong size. i had to send them back but they swapped them out. Other than that, EVERYTHING was there, never had to run back to the parts store, Im sure there quality and service are just as good with the stock set. BTW i wish i would have went with the stock MOOG, just for info in my opinion the POLY is to stiff for trucks, but the 300.00 i paid, i think i will live with it, besides i have gotten use to it now.
2004 Silverado Crewcab (Dark Spiral Gray) |
It probably would have been cheaper to buy it as a kit, but not nearly as easy on the wallet. By buying the parts at O'Reilly I was able to pick them up a few pieces at a time as I could afford them.
I replaced a few individual pieces last year when I had it aligned, so a kit would not have worked well for me anyway. I went with rubber because I hate squeaks, and because the truck rides bad enough already. ![]() Slonaker |
Robert Olson Transport
![]() Join Date: Oct 2002
I was quoted almost $450 for the moog parts from my auto parts store. allignments i havent priced yet cause im still trying to save the $$$ for the parts but im guessing from $50-80 so i guess that is pretty well the national average
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Stylin
i got mine aligned for 35 at the dealer
