PROJECT 7DEUCE
![]() Join Date: Dec 2002
Emblem Install
I FINALLY GOT MY K-5 EMBLEM'S PAINTED AND WOULD LIKE TO INSTALL THEM. MY QUESTION IS CAN I JUST DROP THE INNER WELL OUT OR DO I NEED TO REMOVE THE WHOLE FENDER???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
67-72 Addict!
Just remove the inner. I was able to snake my hand in there without removing mine but I only have the front nut on.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
December 21, 2012
Don't know if you want to use them or not but NAPA has some little type clip things that fit into the holes and the emblem snaps on and off easly.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
yeh just pull the inner fender, little hands help, it is a little fiddling around, but you can do it.
My other Love
little plastic things that go over the studs, then you pressure fit them into the fender, then if necessary later on, you can just pry them off again
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
