05-02-2014, 10:18 PM | #1 |
oops need some help
Ok what happened?2 1/2 dropped spindles.I used the springs that was on the truck.I thought the springs were standard with a little sag.But there straight and the same length.And uncut.So what spring would I need to fix this mess.
05-03-2014, 01:03 AM | #2 |
Re: oops need some help
I don't see whats wrong.........unless you didn't think it was going to drop that much.
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
05-03-2014, 01:09 AM | #3 |
you need one more lug nut as far as I can tell.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
05-03-2014, 07:59 AM | #4 |
Well after cutting out the rear and dropping it on the bump stops.it has less suspension
Travel on the front.The wheel is hitting on the inner fenders.So the truck need to come up some.So how much would the stock spring lift it up?The springs that were on the truck were not installed right.So I have know idea what the ride highth was if they were in properly. |
05-03-2014, 10:51 AM | #5 |
if your truck is really bouncy in the front end then you need some new shocks, it looks like you got a couple inches between your tire and inner fender now.
05-03-2014, 11:54 AM | #6 |
Right now no shocks and its only about 1/2" to the
inner fender. |
