Steering column question
72 c-10 and the guy a bought it from put a newer column in it and I think it's way too long. Does anyone know the original length of a stock column?
Re: Steering column question
I have mine out and can measure it for you if you still need it. I am currently trying to redo it for my build.,
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
Yes!! Please! Mine is like 36". The seat is all the way back and the wheel is in my Chest! I'm thinking I want a 30-32".
I was thinking for some reason the factory was 33 inches, but I may have just dreamed that. boy that is a sad statement if that is what makes up my dreams isn't it.
I've had worse dreams!!! Man I need to cut about 4" of it!
Here are several pics. top to bottom. You can compare the measurements through out the shaft. Hope this helps.
you can shorten your column 4" , there is a couple threads on here about it.
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
Appreciate the pics. Thank you.
