Old 08-11-2013, 12:40 AM   #251
Desperado454
Desperado454's Avatar
Re: Parked Indefinite
Trucks been running pretty good the past while, so I finally decided to order some more parts for it. While I was waiting, I took it up for the long weekend for some camping...
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 08-11-2013, 12:47 AM   #252
Desperado454
...and I went and picked up those parts today. First thing was a shifter for the camaro console that I have. Going to clean it up some more, but I think it's going to look pretty sweet once it's in there:
Also picked up a set of wastegate actuators. Supposedly set for 7.5psi, they'll hopefully work out alright, but we'll see. Can't wait to finally start putting some pressure into this thing..
Here a pic of them:
'28 Model A Build
-Brooks
Old 09-02-2013, 01:51 AM   #253
Desperado454
Well, not too much to report, but made some progress on the center console project. Pics:
'28 Model A Build
-Brooks
Old 09-02-2013, 12:14 PM   #254
moregrip
moregrip's Avatar
looks awesome!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is online now   Reply With Quote
Old 09-10-2013, 01:15 AM   #255
Desperado454
Originally Posted by moregrip View Post
looks awesome!
Thanks man, feels like I'm driving a different truck after I've been using the column shift for so long. I've been having fun manually shifting the gears once in a while to wind 'er up a little more than I usually do. This thing definitely has some potential as it breaks the tires loose in 2nd around 3500rpm once the boost starts to climb to a modest 4psi or so. Now if I could only quit reaching for the phantom column shifter every time I go to put it in park.
Anyways, decided to put my hitch back on today. Been thinking about picking up another project car and wanted to be able to tow the future money pit home should the opportunity arise. I like how most of the hitch is hidden with the bumper 2" lower. I think I'd like it even more if I had the proper bumper on there
'28 Model A Build
-Brooks
Old 09-11-2013, 07:27 PM   #256
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work and I laughed at the phantom column shifter. I go for the clutch every time I get in to an auto vehicle as I always drive a stick.
Ryan
1969 Chevy milk truck
Old 09-21-2013, 10:59 PM   #257
ironroad9c1
Master Hater
I'm here to tell you turbos hate flowcrappers, get some real mufflers.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 10-07-2013, 11:23 PM   #258
Tachout
Following
Tachout is offline   Reply With Quote
Old 10-28-2013, 12:27 AM   #259
Desperado454
What do you recommend?
Originally Posted by Tachout View Post
Following
Kind of a boring update, but it's time to get a heater in this thing. Its a bit of a death trap in the mornings without out a defroster. Since there's just a big void underneath the console i started to fit the old heater core in there. It was a tighter fit than I realized, so i had to angle it in there a little. I'm not too sure how well this is going to work, but it should be better than nothing. Here's some pics of how far I got:
Hoses from the engine:
Coming down the front:
Down the frame:
And into the cab:
Here's the heater core in the console. Still have to wire the fan in and duct it up to the defroster vents, hopefully it'll work out:
Pic in the midst:
I also picked this thing up for the next project. It's a little rougher than what I wanted, but the price was right after talking the guy down quite a bit. Should be fun.
'28 Model A Build
-Brooks
Old 10-28-2013, 03:04 PM   #260
Dieselwrencher
Heater install is looking good. How's the truck doing with the turbos?
Ryan
Old 11-27-2013, 02:48 AM   #261
Desperado454
Post Re: Parked Indefinite
Originally Posted by Dieselwrencher View Post
Heater install is looking good. How's the truck doing with the turbos? I got a 871 (blower off a diesel) for my 354 but I'm still leaning on hanging an HX35 on each bank like you did.
Thanks! The heater ended up working so-so, hoping it'll be good enough to get me through the winter. Truck is doing fine with the turbos, but I'll admit that I've never really pushed it too far. I rely on this thing as a daily driver, so I'm still a little gunshy after I lost a few ring lands with that dinosaur of a turbo I had on a while ago. One day I'll put the screws to it, though I probably should rebuild the former engine with a forged bottom end first, but we'll see. Having said that though, there wouldn't be much that would stop me from trying to rig up your 354 with the 871 and two holsets somehow
'28 Model A Build
-Brooks
Old 05-04-2014, 01:17 AM   #262
Desperado454
Well now that the weather has started to make a turn for the better, i finally got around to installing those wastegate actuators i bought awhile ago. Made up a couple brackets and bolted them in. I've just been putting around with the gates propped open for the winter months, so its going to be fun to see how it respond to a little more pressure. Hope she holds!
'28 Model A Build
-Brooks
Old 05-04-2014, 01:22 AM   #263
y5mgisi
Second Chance Program
y5mgisi's Avatar
Nice! I somehow missed the heater setup! I dig that!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 05-05-2014, 12:13 AM   #264
Desperado454
Thanks, still needs a little fine tuning but it turned out ok.
Wanted to hook up the wideband and since i didn't think to buy a gauge when i picked up the kit, i had to settle for the laptop. Cobbled together a wood stand for it and put it in place. Looks a little goofy but it serves the purpose for now.
'28 Model A Build
-Brooks
Old 05-05-2014, 07:06 AM   #265
MalibuSSwagon
Nice little stand you have there. I actually have the same little laptop I only use for tuning my C10.
MalibuSSwagon is offline   Reply With Quote
Old 05-05-2014, 07:29 PM   #266
Dieselwrencher
Nice work and I'm interested to see how it reacts to more boost. I'm working on my 40 Ford now and seriously thinking about giving it 2 HX35w's as well. How do you like that MSD boost retard box?
Ryan
Old 05-05-2014, 07:38 PM   #267
Gmc-76
Gmc-76's Avatar
I just read through this whole build thread, you sir have creativity and have the knowledge and skill to put that creativity to work. Just plain awesome, keep us updated
Andrew
85 Sierra Classic c10, 305/350/2:73(86k original)
instagram: anabb_98
Gmc-76 is offline   Reply With Quote
Old 05-11-2014, 03:00 AM   #268
Desperado454
Thanks man, these laptops are definitely nice for that. It almost makes me want to wire it up to read throttle position, boost, fuel pressure, and a few others, but that'd probably be overkill for this.
Glad to hear you're working on your 40 now! Do you have a thread on it anywhere? Be a cool project to follow along with. I like knowing i have that msd box in the mix, and it seems to work alright. I really want to get an airline with a regulator and hook up the timing light one day, just to see if its doing as advertised. Be a fun experiment i think anyway
Thanks man!
Well, so far everything's been going pretty good. Pretty sweet hearing these turbos at all times now. Definitely going to have to mess around with the carb, as it has some lean spots, bogs, etc. Rigged up my old iphone to capture some videos, just going to have to find a better place to mount it. Stay tuned...because maybe one day this truck will be too
'28 Model A Build
-Brooks
Old 05-12-2014, 08:09 PM   #269
Dieselwrencher
What fuel pump and size of lines did you end up going with? My biggest thing in putting the turbos is the cost of it all. I may make all the piping and stuff and put the turbos on later. We'll see. The real goal is to drive it in July. That is a big goal as the frame is literally being repaired and the body is on a dolly. haha
Ryan
Old 05-13-2014, 03:13 PM   #270
rudigginit
What are the specs on the motor? Cam, Crank, Pistons, Heads? Looking into single turbo my '82 just curious as to ehat you have holding yours together. And are you using any high pressure head gaskets?
rudigginit is offline   Reply With Quote
Old 05-14-2014, 11:28 AM   #271
Anchorism
Anchorism's Avatar
Very nice center console! I was looking into the horseshoe shifter myself this last week. But ive got bigger fish to fry at the moment.
Anchorism is offline   Reply With Quote
Old 05-22-2014, 01:11 AM   #272
Desperado454
pump is a walbro 255 with -8 lines for the feed and return. I like to think i got my setup done pretty cheap, but i guess it just seems that way since it was spread out. Sounds like a lofty plan, but it doesn't have to be pretty or even all together to be able to drive
I've never had this motor apart so i don't really have exact specs. I'm guessing it has the stock cam, crank, heads and cast pistons though. Doubt the head gaskets are anything special either. I do have a boost retard box on it as well as a wideband which helps preserve things they say, plus i'm only running 8psi or so. Was driving it the other day and it seemed fairly gutless, and wasn't making any boost or turbo noise, couldn't even chirp 3rd for christs sake! Popped the hood and it turned out the tube came off the hat, figured it'd still make the spooling sound but i guess not. Anyways, hooked it back up and now its back to breaking loose halfway through first and spinning till i let up.
Thanks!
'28 Model A Build
-Brooks
Old 05-22-2014, 01:16 AM   #273
rudigginit
Thanks man! Im throwing the idea around of running a single turbo on my 355, stock heads for now but I have speed pro dome head pistons, comp extreme energy cam, dual plane air gap victor jr intake, holley 750 vacuum secondary carb. With your experience do you think I could handle a single turbo?
Old 05-24-2014, 03:18 AM   #274
BC Toy chest
BC Toy chest's Avatar
Thanks for dropping by. I like your truck will stop by to check it out some more.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 05-29-2014, 07:25 PM   #275
Hankster
Hankster's Avatar
This thing is a beast! I want to turbo my 454 in my 86 one day... But got to have money!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
