Old 05-06-2014, 07:21 AM   #1
serge
serge's Avatar
Stock AC vs aftermarket AC
Hello,
I want AC. What is best way to have AC again?
Find stock components to put it back like from factory or install aftermarket system such as vintage air.
My truck is a 70 c20 with AC cab. Under hood all AC equipment gone except for dryer and condenser.
Thanks for your thoughts.
Serge
serge is offline   Reply With Quote
Old 05-06-2014, 08:41 AM   #2
steelhorse
steelhorse's Avatar
Re: Stock AC vs aftermarket AC
By the time you get all new components it may be better to go aftermarket. That way your firewall is clean and it was designed to work with R134.
steelhorse is offline   Reply With Quote
Old 05-06-2014, 08:45 AM   #3
DT1
DT1's Avatar
Originally Posted by serge View Post
Hello,
Serge
I have both systems. My 71 Cheyenne 10 has the stock system with absolutely no modifications and I've been running R134A in it for about six years now. I live in the desert where the temperatures often exceed 110F and the A/C runs comfortably cool. My other car (1967 Mustang) has a Vintage Air R134A system and I have never been satisfied with the performance. It could be because the Vintage Air system that I installed (16 years ago) was one of first systems available. I have heard that the more recent Vintage Air systems are very good now.
DT1 is offline   Reply With Quote
Old 05-06-2014, 08:54 AM   #4
Lattimer
Lattimer's Avatar
Its going to be easier to install an aftermarket kit than to hunt down the stock components. Costs depends on how much good used stuff you can track down. Buying new OE type parts is probably on par with the cost of an aftermarket system.
I went aftermarket for my non-AC truck, and I used http://www.classicautoair.com/
They also sell new OE style stuff for restorations. The aftermarket system is decent. Not perfect by any means, but it works ok and cools well enough that I can drive my truck in the summer. 90+ degrees is somewhat rare here, we get a week or 3 of that most summers. High 80's is the norm.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 05-06-2014, 09:12 AM   #5
cdowns
cdowns's Avatar
new aftermarket systems are far more efficient than the 40year old stuff from stock and it takes less power to run them
Old 05-06-2014, 09:27 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
I run vintage air in my 67 c10 (going on 8 years in it) and a 65 mustang (2nd summer with it). Both are great kits. I recently had an issue with my 65, but it was due to a slow Schrader valve leak on the low pressure side, and I stupidly got my Relays wet (my fault) and ruined them so my compressor wouldn't kit on, all fixed now. The one in the truck has never had issues. My wife loves to be cold and she turns the systems down in either vehicle after 15 to 20 minutes.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-06-2014, 11:28 AM   #7
1972SUPERSB
1972SUPERSB's Avatar
Lightbulb Re: Stock AC vs aftermarket AC
I just finished my AC and put it back like the factory did it. Got all my parts from old air products and cools awesome. Blows about 45 degrees coming out of the vents. The reason I went with the factory setup is everything fit and looks stock and you use all factory wiring, controls and brackets. I didn't want an aftermarket system that you have to modify the fireall and all that. I love the factory look.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 05-06-2014, 12:33 PM   #8
rdgt67
I got a quote for an after market air installed turn key for 2500.thats dual electric fans. My 70 stepside is non ac. Any thoughts from anyone?
rdgt67 is offline   Reply With Quote
Old 05-06-2014, 12:52 PM   #9
cafetony
Install it yourself It's not that hard could be done in a weekend. They give you all the templates. they pay a company to check for leaks and charge.
cafetony is offline   Reply With Quote
Old 05-06-2014, 01:01 PM   #10
cafetony
here is some pics a few tools hole saw drill.
first time installing one it took 8 hr start to finish
Old 05-06-2014, 01:02 PM   #11
mrein3
mrein3's Avatar
If you are starting with a truck that left the factory with AC, you can save about $1000 going stock over aftermarket.
There is nothing wrong with the stock system. The only difference between it and a modern system is that the modern system cycles on and off where stock is on until you turn it off. They will both use about the same amount of engine power while running.
I converted a non-AC truck to AC using stock components. You may find some useful information and part numbers in my post:
http://67-72chevytrucks.com/vboard/s...d.php?t=478564
According to my link above I got $350 into a stock system when starting from a non-AC truck and figured it would be about $200 to re-hab an AC truck (post 8 in link above).
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-06-2014, 07:17 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: Stock AC vs aftermarket AC
I love these kinds posts! All these people except a few of us want AC in there trucks But yet they install after markets in them because they work better... Huh! My 40 some year old AC works great and It was way less than any aftermarket kit ever thought about being. I would just about bet to the ones that have aftermarket AC want cut their dashes though for a new radio.
It works better than stock to!
I would much rather look at a truck done right with factory AC than a aftermarket kit anyday.
My was blowing 40* today and it was 90* outside.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-06-2014, 07:32 PM   #13
rdgt67
Was the 6.0 stock
Old 05-06-2014, 09:31 PM   #14
Andy4639
Old member
Andy4639's Avatar
Originally Posted by rdgt67 View Post
Was the 6.0 stock
No,
It has nothing to do with is it stock are not. It has to do with why is it that some mods are ok on these trucks but some aren't according to some on here. I've moded the heck out of mine and I love it. I would rather see a fire wall with the correct looking AC stuff on it and working than a aftermarket system that just looks completely out of place on these year trucks to me.
My AC looks stock to the normal person but it isn't no where near stock. I just get a kick out of seeing these post that say oh don't cut your dash for a new radio. But then you look at the rest of the truck and it's like lowered, custom seats and interior with a LS motor and such but don't cut that dash!
Put the stock AC on your truck and you will have a lot better looking truck under the hood than with a aftermarket system. + it will resale better also.
Old 05-06-2014, 09:54 PM   #15
rdgt67
I am 66 years old resale is the farthest thing from my mind. N she it comfortable, make it personal, make it cool, make it yours. The naysayers will find enough to critize.
Old 05-07-2014, 10:11 AM   #16
serge
serge's Avatar
WOW! Thanks for the feed back guys.
Some great points.
I will admit that stock is my preference but I'm a hands on person but not sure if able to figure out whats needed (most parts gone) and how to install. Reading the reply from Mrein3 gives me a little more confidence.
On the other hand Vintage or similar appear to be do-it yourself friendly.
Will keep researching. .
Thanks again
Old 05-07-2014, 10:20 AM   #17
boostedc10
boostedc10's Avatar
If you want a compact clean look go with the aftermarket, if you want a stock look go stock its that simple. Both systems are more than capable of cooling a small cab. You can even go to R134 on the old R12 system so that is a mute point too.
boostedc10 is offline   Reply With Quote
Old 05-07-2014, 05:47 PM   #18
Fitz
Hello,
Serge
Aftermarket! The firewall will be much cleaner and the unit will run better too!
Fitz is offline   Reply With Quote
Old 05-13-2014, 02:40 PM   #19
chevy72blu
chevy72blu's Avatar
My 72 had factory air and now has an LS1 with f body accessories. I removed the compressor as it conflicts with the frame... now I'm at the point where I'm ready to look into AC. I understand that the stock variable compressor will not work. So it looks like I'll need a sanden compressor with the kwikperf mount.
The Vintage air kit looks great but it sure is spendy. I still have most of my original AC setup (condenser, evaporater, etc). Can any of this be re-used or do I need to go to an all new setup for R134?
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-13-2014, 03:02 PM   #20
boostedc10
boostedc10's Avatar
The problem with converting a R-12 system to R-134 system is a few things;
The compressor will work harder
The condenser is too small for the system to work efficiently
PAG oil turns to a gel when mixed to mineral oil
I know people have swapped the fittings and called it a day but "most" of the time this never lasts. Additionally the stock lines in the truck are not barrier hoses and with R-134 having a smaller molecular structure it usually finds a way out through them.
If it was me I would either stick with R-12 or swap the entire system over to R-134, but that is just me.
Old 05-13-2014, 03:14 PM   #21
jborders
jborders's Avatar
I've had a vintage air system for about 15 years . Works great I'd use them again.
jborders is offline   Reply With Quote
Old 05-13-2014, 05:16 PM   #22
Lee H
Lee H's Avatar
I have vintage air in my factory AC truck and really like it. It's probably one of the best upgrades I've made. Before I installed the VA system I had an AC shop evac my factory system, change the fittings, and charge with 134. It cooled well for about ten years without service. I know many others that have gone this same route, some ran good for a long time and some did not. After my refurb I just could not justify the cost of rebuilding and hanging that 40 year old monstrosity on my firewall. The VA kit was only a few hundred more than procuring all the stuff I needed (new compressor, condenser, dryer, heater core, poa, hoses, etc.) I know some things can be had on the reconditioned market but they are iffy at best and not a good comparison to an all new After market kit.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-13-2014, 05:38 PM   #23
john
member #16
john's Avatar
Check this out serge, Used unit on the parts board if you want to stay original.
http://67-72chevytrucks.com/vboard/s...d.php?t=620209
john is offline   Reply With Quote
Old 05-13-2014, 07:20 PM   #24
Andy4639
Old member
Andy4639's Avatar
Wink Re: Stock AC vs aftermarket AC
Yes you can use the factory box but buy new parts to run 134-A. Mine runes great. I have a LS 6.0 LQ4 in mine now.
Old 05-13-2014, 07:33 PM   #25
rdgt67
Is that a hard swap on the motor?
