Old 04-29-2014, 09:22 AM   #1
smartass12
smartass12's Avatar
Checking for spark?
Im trying to figure out why i cant get my 5.3 swap to fire. Can i check for spark
by removing plug, ground plug and then turn motor over and look for spark? And if that is correct and i see spark i would assume that means the coil is good and getting power? thanks for the help
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 04-29-2014, 09:44 AM   #2
Custom 68
Custom 68's Avatar
Re: Checking for spark?
Yes you should be able to check for spark like that. Depending what it is you may need to check your tune it could have VATS or something like that still keeping it from running.
check for spark but it could be your injectors being "clogged" that is very common these days it seems the gas can gum up pretty quickly.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-29-2014, 10:40 AM   #3
smartass12
smartass12's Avatar
thank, i will check for that first then more to fuel pressure and injectors
Old 04-29-2014, 05:36 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Make sure VATS is off first and foremost.
Then check stuck injectors
Then check the little ground wires on the coilpack harnesses
These engines will start on like 4-5 cylinders, and since they run COP there really isn't a way to have multiple spark failures unless something else big is going on.
Even though it won't fire, sometimes you can cheat and use a codescanner. You will most likely have a bunch of false codes (Since the engine never actually ran), but in some cases you can pick the "odd one out" to help track down a problem.
We need some more info as well; stock motor or does it have cam etc? Who tuned it?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-29-2014, 09:45 PM   #5
siggyfreud
siggyfreud's Avatar
Couldn't it also be a bad or disconnected cam or crank pickup sensor?
siggyfreud is offline   Reply With Quote
Old 04-30-2014, 08:49 AM   #6
smartass12
smartass12's Avatar
stock motor base tune by lt1swap.com
Old 04-30-2014, 09:23 AM   #7
Custom 68
Custom 68's Avatar
I am still betting on stuck injectors. Mine were and I keep reading of others with the same issues.
Dave
Old 04-30-2014, 10:27 AM   #8
truckdude239
truckdude239's Avatar
spray some starter fuild in teh inatk and see if it starts if it does you have a fuel issuse
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-02-2014, 08:54 AM   #9
smartass12
smartass12's Avatar
Didnt think of that. Thanks will try
Old 05-06-2014, 10:30 AM   #10
smartass12
smartass12's Avatar
So after trying to spray starter fluid in the throttle body it does try to start a little but doesnt completely start and run. Also, shouldnt the schrader valve on the fuel rail have pressure, cuz when i push it in i get no fuel spraying out. Another wierd thing is now when i turn the key i dont hear the fuel pump come on anymore
Old 05-06-2014, 10:57 AM   #11
smartass12
smartass12's Avatar
So found out the ground on my fuel pump was loose, so it is kicking on again. What should the voltage read for that two second purge? just tested it before i have to leave for work and it only jumps to about 3-4 volts real quick
Old 05-06-2014, 11:03 AM   #12
Custom 68
Custom 68's Avatar
That is great. so was this running before you posted this?
I would believe the voltage should be 12+ volts. Check it when it is started.
Dave
Old 05-07-2014, 12:23 AM   #13
littlevictories
the voltage coming from the pcm and going to the relay should be low like = or < 5v
but the juice coming from the relay and going to the pump should be >12v
littlevictories is offline   Reply With Quote
Old 05-07-2014, 12:44 AM   #14
ls1nova71
ls1nova71's Avatar
The PCM supplies 12v to the relay, so for the two second prime you should have 12v.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-07-2014, 07:46 AM   #15
smartass12
smartass12's Avatar
no i have never heard this motor run
ok, i will have to figure out why it is not
Old 05-07-2014, 09:22 AM   #16
Custom 68
Custom 68's Avatar
so like said here if you are checking the voltage coming from the computer it wont be 12 volts. The siginal from the PCP needs to go to a relay and it will trip the relay and supply the 12 volts to the pump.
good luck
Dave
Dave
Old 05-07-2014, 10:09 AM   #17
ls1nova71
ls1nova71's Avatar
good luck
Dave
There are 5v references in the PCM that are for sensors, but it WILL BE 12v coming from the PCM to the fuel pump relay, it takes 12v to run a 12v relay. You can't just run the pump off of it because the pump will draw more amperage than the PCM can handle.
Old 05-07-2014, 01:31 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You CAN jump the FP relay straight off a switched power source, just to make sure the pump turns on and everything works etc.
0-5v is usually considered reference voltage, for things like gauge outputs etc. 5v won't energize a 12v circuit
Old 05-11-2014, 12:17 PM   #19
smartass12
smartass12's Avatar
after testing...so it only goes to about 11v for the first two seconds and down to around 9v when trying to start. Zero pressure at fuel rail (checked by just pressing schrader valve and no gas......could it be wire size and length for fuel pump? what i have is 12gauge wire from battery (rear of bed) to fuel pump relay (in cab) then 12gauge off relay to fuel pump (rear of bed).
Old 05-11-2014, 12:30 PM   #20
ivorton74
ivorton74's Avatar
I have the same issue with my truck...I thought it was from not having enough gas in the tank but my buddy thinks it could be because of the vats. I hope its not that. also had my pcm tuned by Brendan from lt1swap...check out my starting vid...https://www.youtube.com/watch?v=XGUmroZK3Dw
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 05-11-2014, 01:02 PM   #21
smartass12
smartass12's Avatar
Watched your video..mine kinda does that if i spray starter fluid in throttle body but if not just cranks over only
Old 05-11-2014, 01:31 PM   #22
ivorton74
ivorton74's Avatar
ill put more gas in it n hopefully it starts up...i'd hate to send my pcm back to Brendan...dnt need another set back
Old 05-11-2014, 02:48 PM   #23
ls1nova71
ls1nova71's Avatar
Don't think its wire size and the voltage should come up when its running. Like BR3W said, jump the relay so it runs all the time to test it. Make sure the pump isn't wired backwards, sounds like that is your problem.
Old 05-12-2014, 08:21 AM   #24
smartass12
smartass12's Avatar
I will try jumping it. when you say wired backwards just switch connections at terminal?
Old 05-12-2014, 10:56 AM   #25
smartass12
smartass12's Avatar
So i pulled the fuel line after the fuel filter and turn the key on...the pump pushed a nice heavy flow of fuel out the line for the two seconds..that leads me to believe the pump is hooked up correctly. should i consider replacing the pressure regulator on fuel rail at this point because when i turn the key several time and try to crank it over i get no pressure out of the shrader valve after doing so, or will the pressure only be present durning crank?
