Old 04-29-2014, 08:48 AM   #226
Number98
Prestige Worldwide
Number98's Avatar
Re: The GSFMech Build
Great detail job under the hood.... this is one great looking truck!
Number98 is offline   Reply With Quote
Old 05-06-2014, 09:49 AM   #227
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Did you make any changes to your motor when you rebuilt it?
Tom Vogel is offline   Reply With Quote
Old 05-06-2014, 10:18 AM   #228
GSFMECH
On the road
GSFMECH's Avatar
Yeah sure did, I made a lot of changes. I wanted a little more thump even though it ran good before and was impossible to hook up. I was running L2465 Speed Pro pistons before and 781’s but they were stock except for a 3 angle valve job and had a lot milder cam. I machined the heads for 2.19 and 1.88 SS valves with the cut down stems, and machined them for PC seals and comp cams dual springs and did a real nice bowl porting and 3 angle seat job. Factory steel crank, 3/8” truck rods and I had aquired a vintage set of L2349 TRW closed chamber 30 over pistons that I used this time, this boosted the compression a little. With a set of steel shim gaskets it came out to 10.3:1. I also had it balanced. I added an old style LS-7 corvette trap door oil pan, windage tray and oil pump (Chevy still carries this stuff). Lunati Voodoo cam, GM long slot rockers, performer RPM intake, I modified my 850 double pumper for 4-hole idle to try and get some of the hit out of the cam with the AC on, Mallory coil and pertronix ignition, big tube full length Hooker Chevelle headers. I also went with a TCI breakaway converter. It runs real good but it took a few months tinkering to get the advance curve and spark plug heat range right. It was a ping monster for awhile but it’s just about sorted out. I still need to play with the jetting a little more.
Thanks for all the compliments ya’ll
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 05-06-2014, 10:38 AM   #229
Graham57a
Graham57a's Avatar
Beautiful truck! Love a solid paint cheyenne with full trim, especially lowered on coys! Quick question, when you dyed your seat belts how did you keep the white tags from getting color on them? I've wanted to do this for a while but was afraid of dying the tags.
Graham57a is offline   Reply With Quote
Old 05-06-2014, 10:49 AM   #230
Fatherof3
Fatherof3's Avatar
Nice truck! Love it
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 05-06-2014, 11:33 AM   #231
jlsanborn
jlsanborn's Avatar
Sounds like a really cool motor! Those are a domed piston right? Are you able to run pump gas?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 05-06-2014, 02:59 PM   #232
Bennett68C10
Bennett68C10's Avatar
We need a video of that bad boy, what Voodoo cam did you go with. Roller or flat tappet?
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-06-2014, 07:38 PM   #233
GSFMECH
On the road
GSFMECH's Avatar
This was weird, when I dyed them I thought it would mess up the tag but the dye never touched the tags, it had no affect on them at all.
Mike
Old 05-06-2014, 07:41 PM   #234
GSFMECH
On the road
GSFMECH's Avatar
Yes they have domes. It took a lot of tuning but yes I can run 93 octane pump gas. A lot of it is keeping the quench height close as you can when you build the motor. I'm running right around .040"
Mike
Old 05-06-2014, 07:48 PM   #235
GSFMECH
On the road
GSFMECH's Avatar
It's a hydraulic flat tappet No. 10110703LK, specs are int .542 Exh 554, Duration @ .050 Int 227 Exh 233, 110 L.S. I grooved the lifter bores to help lube the cam and use Valvoline VR-1 With Zinc additive. I don't have a video of it but if I did I wouldn't know how to load it
Mike
Old 05-10-2014, 08:50 AM   #236
smbrouss70
smbrouss70's Avatar
Take a video of it when you get home, we'll get it loaded for you.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-10-2014, 08:56 AM   #237
GSFMECH
On the road
GSFMECH's Avatar
Will do Steven, Barry had one he posted on facebook way back but I don't know what happened to it.
Mike
Old 06-10-2014, 04:38 PM   #238
nsulacountry
Originally Posted by GSFMECH View Post
Last for now.
Oh yeah, for those that asked the Lizard skin makes a BIG difference. You can't feel any engine heat at all and it's much quieter. I can't wait for warm weather and try the AC.
Cheesing for the camera at Stine's I see! Glad to see a local on here. I'm on the two step plan. Step 1, build shop. Step 2 tear down the 1979 C20 and insert a Vortec 8.1L... My plan for now!
CT
nsulacountry is offline   Reply With Quote
Old 06-12-2014, 07:20 AM   #239
GSFMECH
On the road
GSFMECH's Avatar
How bought that, another one from Natchitoches. There are a few of us on here.
Mike
Old 06-12-2014, 08:19 AM   #240
Bennett68C10
Thanks for the cam specs, I was looking at that same one. Do you have any issues producing enough vacuum for your power brakes and AC? How is the idle on it, nice and lumpy
Keith
66 Suburban
IG: bennett68c10
Old 06-12-2014, 09:15 PM   #241
GSFMECH
On the road
GSFMECH's Avatar
To be honest I’m struggling a bit with the AC, the idle is pretty lumpy. I idle it up when I run the AC. No problems at all with the brakes, it has decent vacuum, right around 10” or so.
Mike
Old 06-12-2014, 09:19 PM   #242
Bennett68C10
Thanks, this is what I'm worried about with mine, it has a really lumpy cam and I'm worried about the AC.
Keith
66 Suburban
IG: bennett68c10
Old 06-12-2014, 09:19 PM   #243
GSFMECH
On the road
GSFMECH's Avatar
New addition, comfort grip steering wheel, I love this thing!!
Mike
Old 06-12-2014, 09:46 PM   #244
Hart_Rod
Hart_Rod's Avatar
Nice!
Hart_Rod is offline   Reply With Quote
Old 06-23-2014, 09:33 PM   #245
GSFMECH
On the road
GSFMECH's Avatar
I ran across this photo from last year and I thought it was cool so I had to post it. This is Wynne (HuggerCST) and me going down the highway.
Mike
Old 06-23-2014, 09:51 PM   #246
jeh
jeh's Avatar
Cool pic...
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 06-23-2014, 10:04 PM   #247
cericd
cericd's Avatar
Love the pic. Perfect rake in my opinion.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 06-23-2014, 10:35 PM   #248
Bennett68C10
Sweet pic of a couple beautiful trucks
Keith
66 Suburban
IG: bennett68c10
Old 06-24-2014, 08:05 AM   #249
mcbassin
Still Learning
mcbassin's Avatar
I think have the same steering wheel you bought.
Very cool picture.
Old 10-20-2014, 01:14 AM   #250
j carter
Love this truck
j carter is offline   Reply With Quote
