Old 05-05-2014, 06:59 PM   #1
terbronco7
terbronco7's Avatar
Vibration when I let off accelerator.
I have a vibration really only notice it when I am above 40 mph and I let off accel, I thought it could be my wheels and tires but have since got new rims and tires, its better but still there. Any ideas as to what is causing this?
Thanks. It is a 4 speed with granny if this helps any.
terbronco7 is offline   Reply With Quote
Old 05-05-2014, 07:25 PM   #2
63burban
Chevy addict
Re: Vibration when I let off accelerator.
Check your universal joints on your drive shaft, worst scenario is the carrier bearing or pinion bearings.
63burban is offline   Reply With Quote
Old 05-06-2014, 06:42 AM   #3
PGSigns
PGSigns's Avatar
Do you feel it in the front or back of the truck?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-06-2014, 09:45 AM   #4
terbronco7
terbronco7's Avatar
Thanks I will be replacing those this weekend.
Old 05-06-2014, 09:46 AM   #5
terbronco7
terbronco7's Avatar
Jimmy
Its hard to say, seems like its more center of truck. if I depress the clutch it gets better but still there as well.
Old 05-06-2014, 11:12 AM   #6
Keith Seymore
Keith Seymore's Avatar
Driveline disturbances are load dependent. They can appear on drive (steady state), accel and/or coast (any and/or all of the above).
Tire/wheel disturbances are not throttle dependent.
Sounds like driveline to me (u joints, or angles).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-06-2014, 11:30 AM   #7
old cool
Please read "noises in drive line" . I posted last week. Gotten lots of great feedback. I have similar problems. Scoop is, trial and error fixups could be expensive.
My sound is most profound when I push the clutch in between shifts and then while rolling in 3rd gear on flat surface(i have 3 speed). When I push the accelerator down is makes more of a normal sound (working engine and trans). When I let off or just drive at normal speed in 3rd without pushing it, it goes vrrrrrrrrr with some fluctation as I intermittently touch gas pedal to keep speed maintained. Sound never stops. NOTE: Pushing down on accelerator is not when it drives me nuts. It's while I'm cruising along and between shifts. Oh yea, while driving down hill I put the truck in nuetral and it did get quieter but still heard the sound. I will be watching your post.
This may be out in left field, but I wonder if tie rods and poor ball joints would cause wheel bearings to shift in and out and this cause the vrrrrrrr. Up to a point I think it could be a problem -- but then why would it quiet when I was going down hill in neutral? I think I've answered my own question. Yea, back to drawing board.
old cool is offline   Reply With Quote
Old 05-06-2014, 11:33 AM   #8
old cool
Keith Seymore. I like the logic to your comment. I believe you responded to me as well. "old cool"
Old 05-06-2014, 11:44 AM   #9
geezer#99
geezer#99's Avatar
When you do u-joints check your pinion angle.
Usually when you back off the loud pedal at speed and it vibrates it's the pinion angle. The pinion drops slightly making the u-joint vibrate.
If you've lowered your truck your pinion angle could be off.
Old 05-06-2014, 02:30 PM   #10
PGSigns
PGSigns's Avatar
Pinion is not going to move much on a trailing arm truck. If the pinion bearing is going south along with anything from it to the clutch it could be causing the issue. Since it gets better when you push in the clutch that is taking the load off the driveline. I would check the oil levels in the trans and rear and look for anything that is worn out.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-06-2014, 03:07 PM   #11
terbronco7
terbronco7's Avatar
All these will be checked truck was lowered, I think rear is stock front def not PO did this, as for oil in tranny it def makes alot of noise where if at all can I put oil in the standard 4 speed with granny def sounds like it needs it for sure.
Old 05-07-2014, 06:34 AM   #12
luvbowties
luvbowties's Avatar
Wink Re: Vibration when I let off accelerator.
Jimmy
Had a good-mechanic-friend tell me when I was a kid[we got our driv. lic. at 14 yrs. old] that the "back side" of my diff'l gears were worn? Had me verifying his diagnosis at the other garages in nearest town before he laughed heartily at my having taken him so seriously.
Sam
luvbowties is offline   Reply With Quote
Old 05-07-2014, 06:37 PM   #13
spacedebris
lots of good advice here. I dont know if this will qualify but here goes. You may also want to check the exhaust. My grandfather had a similar issue a number of years ago where he would get a vibration when decelerating. turned out to be one of the exhaust hangers had wobbled out a little and when decelerating it allowed the whole exhaust to vibrate. By pushing the clutch the RPM would fall off and the vibration would get better. Just something else to check.
spacedebris is offline   Reply With Quote
Old 05-07-2014, 08:25 PM   #14
terbronco7
terbronco7's Avatar
Thats interesting I will check that out as well. Thanks
