05-05-2014, 04:28 PM | #626 |
Re: What did you do to your truck today? Chapter II
Now what?????????????
(Torch was not there to cut, had to heat up the rivets a bit to get the old cab mounts off) |
05-05-2014, 05:16 PM | #627 | |
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
05-05-2014, 06:16 PM | #628 |
I cleaned, primed and painted one head... Doing the second one tomorrow... while the waiting continues...
05-05-2014, 09:44 PM | #629 |
The last of the fuel lines are now out! It was a bit of an annoyance but I managed to remove these without resorting to cutting or even bending.
I am a bit fearful of putting the new ones back in, just because it was so much hassle getting the old ones out and I'm even considering using braided steel lines for replacements but I think I can do this. |
05-06-2014, 07:02 PM | #630 |
today i replaced the old rusty Grant gt steering wheel the PO had installed with a wheel i took off of an old column that was laying around.
05-06-2014, 07:53 PM | #631 |
Finished installing Alan Grove power steering pump bracket. Now I have better clearance between the pump shaft and the alternator belt.
1970 C10 Short Stepper with 71/72 front clip. |
05-06-2014, 09:42 PM | #632 |
05-06-2014, 09:52 PM | #633 |
Where did you get your alt brackets? I like those.
1970 SWB Build |
05-06-2014, 09:55 PM | #634 |
I pulled the 350 out of my 68 C20! Took all day but I am stoked to be able to get in and clean er' up! Going to paint the engine pocket black and the engine and trans red! Stoked!
05-06-2014, 10:07 PM | #635 |
Painted the second head today... Hoping my new rods that have been back ordered for 5 weeks now finally ship tomorrow...
05-06-2014, 11:41 PM | #636 |
Finally everything is bolted on.fuel lines , new power steering hoses and new belts installed. Vacuum lines next, and then on to core support and body panels so electrical has a place to lay.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
05-07-2014, 01:31 PM | #637 |
saved it from the woods
05-07-2014, 02:10 PM | #638 |
You did REAL ! Good!
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
05-07-2014, 02:20 PM | #639 |
05-08-2014, 03:13 AM | #640 |
@zbm100 that is awesome. Plus the pic , just so everyone knows exactly what you mean by "the woods". lol.
05-08-2014, 06:46 AM | #641 |
I got mine on eBay. Look up Alan Grove web site. They come in bare metal. You have to plate or paint them. I had to open up the two holes that attach the bracket to the front of the block to get it all bolted together. Kind-of a PIA in that location with the engine installed.
EDIT....I bought it on Amazon.
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 05-08-2014 at 04:09 PM. |
05-08-2014, 02:38 PM | #642 |
not good
05-08-2014, 04:15 PM | #643 |
Old member
Installed a new Sony head unit with bluetooth! I'm ready for the Power Tour now. Just have to figure it all out and how to use it. I have the Iphone stuff figured out pretty good I think.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-08-2014, 04:25 PM | #644 |
Did this...
http://youtu.be/vAaT_juP-Ms Took it for a little longer cruise around the area later that day, only to run out of gas, and collapse my fuel filter. Still have some fine tuning on the carb, and some issues inside the steering column to address. Its getting there.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
05-08-2014, 04:48 PM | #645 |
I spent $50.00 dollars and bought all the tubing, hoses, and most of the clamps I need for the fuel line replacement. Lucked up and caught the tubing 1/2 off! I still need the extra filter and a couple more clamps.
05-08-2014, 10:52 PM | #646 |
Finished the bodywork on my box!
05-08-2014, 11:41 PM | #647 |
Installed the radiator, new vacuum advance in the distributor, 2 new tires on the back, 1 new headlight, new spark plugs. Tomorrow I take it to get inspected!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
05-08-2014, 11:55 PM | #648 |
05-09-2014, 08:54 PM | #649 |
I got the windshield and rear glass installed today. Then instal a new dash pad and started to assemble the glove box.
05-09-2014, 10:00 PM | #650 |
So, it didn't pass inspection. failed because of one ball joint and there's no windshield washer.
