Old 05-04-2014, 09:16 AM   #351
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project: Shiro
Originally Posted by duallyjams View Post
Very subtle bet most people won't even notice.
Yep, I didn't want to get into the raised ribs in the bed floor. This gave me the clearance I needed with minimal fabrication, which is good because my sheet metal welding skills are a little rough. I like welding on the thick stuff where you can really burn it in.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-04-2014, 10:00 AM   #352
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project: Shiro
Looks great.
Keith
Convert to disc brakes.
Old 05-04-2014, 12:59 PM   #353
Bennett68C10
Bennett68C10's Avatar
Re: Project: Shiro
Nice job
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-06-2014, 06:26 PM   #354
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: Project: Shiro
Very cool build...your son will love it
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 05-08-2014, 10:01 PM   #355
C10_ustacould
Re: Project: Shiro
Looks great.
Originally Posted by Bennett68C10 View Post
Nice job
Thanks guys. This will be a learning curve for me as I have never really messed with sheet metal. I am going to go through the set up on my welder and buy the right grinding discs etc to try and set myself up for success.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-08-2014, 11:39 PM   #356
C10_ustacould
Re: Project: Shiro
The Big Brown Truck dropped off some parts today: my narrowed control arms from Porterbuilt and an NOS passenger side rocker to make it a pair. Ordered a core support, inner fenders and cab corners from AMD this week, more parts for when we get started. Also, took the old girl out to stretch here legs for a bit tonight.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-09-2014, 07:51 AM   #357
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
Looks like some very nice parts. Looking forward to seeing them installed.
Old 05-09-2014, 07:55 AM   #358
lolife99
lolife99's Avatar
Re: Project: Shiro
Are the PB a-arm bushings now drilled for grease zerks?
Keith
Old 05-09-2014, 08:21 AM   #359
C10_ustacould
Re: Project: Shiro
The uppers are, I haven't taken the lowers out of the box yet.
edit: Keith, your avatar pic is awesome by the way!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-09-2014, 08:22 AM   #360
C10_ustacould
Re: Project: Shiro
You and me both!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-09-2014, 11:30 AM   #361
knomadd
knomadd's Avatar
Re: Project: Shiro
Interesting... When I asked about the lowers several months ago, I was told they didn't need grease zerks since they used delrin bushings. I wonder what changed their mind?
Parts look great though. Looks like you're collecting some quality stuff.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-09-2014, 11:48 AM   #362
C10_ustacould
Re: Project: Shiro
Yep, now I need to spend some quality time installing all this stuff!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-09-2014, 12:23 PM   #363
lolife99
lolife99's Avatar
Re: Project: Shiro
I'm sure grease couldn't hurt.
I know of one truck that the owner complained about a slight squeak on the bushing.
I'm sure adding a grease zerk will prevent this.
Keith
Old 05-09-2014, 12:59 PM   #364
C10_ustacould
Re: Project: Shiro
My lowers have them too. bad pic, but you get the idea.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-09-2014, 01:09 PM   #365
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
Mirror placement measurements:
http://67-72chevytrucks.com/vboard/s...mounting+holes
Hart_Rod is offline   Reply With Quote
Old 05-22-2014, 09:20 PM   #366
C10_ustacould
Re: Project: Shiro
Columns and shift-gate question for the C10 gurus; If I use a late model 5.3L/6L80E set up which only uses PRNDM (M for manual mode) will the shift-gate in a factory tilt match up? Were tilts available with the powerglide transmission (PRNDL) option? Seems like a perfect marriage between old and new school. With the 4L60E the shift-gates and the indicator (PRNOD21) never really jived. If this will work I plan to use a factory tilt with the powerglide shift indicator. Thoughts?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-22-2014, 09:49 PM   #367
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
There is no shift gate in the tilt, it's in the transmission.
Old 05-22-2014, 11:23 PM   #368
C10_ustacould
Re: Project: Shiro
If this is true why do you have to pull it to you to shift out of Park, and why can't you pull it straight from park to first? There must be something in the column that stops it from falling out of one postion and into the next. I would agree the transmissions have a detent, but the column must have something too.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-23-2014, 12:18 AM   #369
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
I wish I knew the answer to this too. I just installed my Lokar linkage on my Factory GM tilt (LINK)and with my 4L60E Transmission the PRND321 doesn't match up worth a crap. It goes from P to N when you go from park to reverse. I may have it adjusted wrong?
There is a steel piece inside the column that has notches that seem to like they need synched with the transmission...?
LINK
Old 05-23-2014, 07:42 AM   #370
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
You are correct about PARK. Factory tilts and aftermarket tilts have a "safety" detent. All the rest of the detents (position lock) are in the transmission. As far as the column, some of the older columns (non-tilt) did have some built in detents. The tilt column in my 68 is factory if you want to try it out sometime, .
LINK
Mike - you just have to keep playing with it, it takes time and patience to do. I spent about 2 hrs yesterday messing with one and got it close, but it still needs some more adjusting. If you have someone to help you, it goes a lot quicker....
One other thing I forgot to mention, depending on where you engine is located in your truck, you may need to order a longer shift rod from LOKAR. I had to use a long one on all three of my trucks and they are all positioned in the truck differently and have different transmissions.
Here's a good video on how to set it up:
Old 05-23-2014, 08:36 AM   #371
C10_ustacould
Re: Project: Shiro
Here's a good video on how to set it up: 1972 K25 - Lokar Shift Linkage Part 2 - YouTube
LOL, I'll need to spend some time inspecting and evaluating the operation of the shifter... 3 days should do it... I'll just come get it for the weekend.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-23-2014, 08:44 AM   #372
Hart_Rod
Hart_Rod's Avatar
Re: Project: Shiro
Keys are in it..... You'll have to put the vent windows back in before you can drive it though.......
Old 05-23-2014, 09:03 AM   #373
C10_ustacould
Re: Project: Shiro
I've done a few of those recently, wouldn't take a minute.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-23-2014, 10:24 AM   #374
lolife99
lolife99's Avatar
Re: Project: Shiro
Buck,... the track width of your front wheels has bugged me ever since you put them on.
Are you sure they are 5.25" backspace?
I just checked on AR's website and they only show a 4.95" BS on the 20x8.5 wheel.
http://www.americanracing.com/wheels...8017/techsheet
It won't be an issue with your narrowed Porterbuilt a-arms,... but I was trying to see why they stuck out as far as they did.
Does your truck have the Modular CPP spindles on it?
It appears the rear 20x9.5 wheels have a 5.84" BS,... that's why you were so close to your wheel tubs.
Keith
Old 05-23-2014, 10:45 AM   #375
C10_ustacould
Re: Project: Shiro
You know I never measured, I thought I read the backspacings were 5.25 and 5.50... Went back and checked Tommy's ads and it states the 9.5s are a 5.85 bs, I over looked it. No matter as I like the tucked look they have, just need to get the front tucked too. My current spindles are not the modular style but I will be swapping to 63-70 drop spindles to better work with the rack n pinion in my PB kit so I will certainly have them when it's done and on coil overs.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
