05-04-2014, 09:16 AM | #351 |
A day late and $1 short...
Re: Project: Shiro
Yep, I didn't want to get into the raised ribs in the bed floor. This gave me the clearance I needed with minimal fabrication, which is good because my sheet metal welding skills are a little rough. I like welding on the thick stuff where you can really burn it in.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
05-04-2014, 10:00 AM | #352 |
67-72 parts collector,…
Re: Project: Shiro
Looks great.
05-04-2014, 12:59 PM | #353 |
Re: Project: Shiro
Nice job
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-06-2014, 06:26 PM | #354 |
C-10 Club Member
Re: Project: Shiro
Very cool build...your son will love it
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
05-08-2014, 10:01 PM | #355 |
Re: Project: Shiro
Thanks guys. This will be a learning curve for me as I have never really messed with sheet metal. I am going to go through the set up on my welder and buy the right grinding discs etc to try and set myself up for success.
05-08-2014, 11:39 PM | #356 |
Re: Project: Shiro
The Big Brown Truck dropped off some parts today: my narrowed control arms from Porterbuilt and an NOS passenger side rocker to make it a pair. Ordered a core support, inner fenders and cab corners from AMD this week, more parts for when we get started. Also, took the old girl out to stretch here legs for a bit tonight.
05-09-2014, 07:51 AM | #357 |
Still Learning
Re: Project: Shiro
Looks like some very nice parts. Looking forward to seeing them installed.
05-09-2014, 07:55 AM | #358 |
Re: Project: Shiro
Are the PB a-arm bushings now drilled for grease zerks?
05-09-2014, 08:21 AM | #359 |
Re: Project: Shiro
The uppers are, I haven't taken the lowers out of the box yet.
edit: Keith, your avatar pic is awesome by the way!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 05-09-2014 at 08:29 AM. |
05-09-2014, 08:22 AM | #360 |
Re: Project: Shiro
You and me both!!
05-09-2014, 11:30 AM | #361 |
Re: Project: Shiro
Interesting... When I asked about the lowers several months ago, I was told they didn't need grease zerks since they used delrin bushings. I wonder what changed their mind?
Parts look great though. Looks like you're collecting some quality stuff.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
05-09-2014, 11:48 AM | #362 |
Re: Project: Shiro
Yep, now I need to spend some quality time installing all this stuff!
05-09-2014, 12:23 PM | #363 |
Re: Project: Shiro
I'm sure grease couldn't hurt.
I know of one truck that the owner complained about a slight squeak on the bushing. I'm sure adding a grease zerk will prevent this.
05-09-2014, 12:59 PM | #364 |
Re: Project: Shiro
My lowers have them too. bad pic, but you get the idea.
05-09-2014, 01:09 PM | #365 |
Re: Project: Shiro
Mirror placement measurements:
http://67-72chevytrucks.com/vboard/s...mounting+holes http://67-72chevytrucks.com/vboard/s...mounting+holes
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-22-2014, 09:20 PM | #366 |
Re: Project: Shiro
Columns and shift-gate question for the C10 gurus; If I use a late model 5.3L/6L80E set up which only uses PRNDM (M for manual mode) will the shift-gate in a factory tilt match up? Were tilts available with the powerglide transmission (PRNDL) option? Seems like a perfect marriage between old and new school. With the 4L60E the shift-gates and the indicator (PRNOD21) never really jived. If this will work I plan to use a factory tilt with the powerglide shift indicator. Thoughts?
05-22-2014, 09:49 PM | #367 |
Re: Project: Shiro
There is no shift gate in the tilt, it's in the transmission.
05-22-2014, 11:23 PM | #368 |
Re: Project: Shiro
If this is true why do you have to pull it to you to shift out of Park, and why can't you pull it straight from park to first? There must be something in the column that stops it from falling out of one postion and into the next. I would agree the transmissions have a detent, but the column must have something too.
05-23-2014, 12:18 AM | #369 | ||
Still Learning
Re: Project: Shiro
LINK
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 05-23-2014 at 12:37 AM. |
05-23-2014, 07:42 AM | #370 | ||
Re: Project: Shiro
One other thing I forgot to mention, depending on where you engine is located in your truck, you may need to order a longer shift rod from LOKAR. I had to use a long one on all three of my trucks and they are all positioned in the truck differently and have different transmissions. Here's a good video on how to set it up:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-23-2014 at 08:03 AM. |
05-23-2014, 08:36 AM | #371 | |
Re: Project: Shiro
05-23-2014, 08:44 AM | #372 |
Re: Project: Shiro
Keys are in it..... You'll have to put the vent windows back in before you can drive it though.......
05-23-2014, 09:03 AM | #373 |
Re: Project: Shiro
I've done a few of those recently, wouldn't take a minute.
05-23-2014, 10:24 AM | #374 |
Re: Project: Shiro
Buck,... the track width of your front wheels has bugged me ever since you put them on.
Are you sure they are 5.25" backspace? I just checked on AR's website and they only show a 4.95" BS on the 20x8.5 wheel. http://www.americanracing.com/wheels...8017/techsheet It won't be an issue with your narrowed Porterbuilt a-arms,... but I was trying to see why they stuck out as far as they did. Does your truck have the Modular CPP spindles on it? It appears the rear 20x9.5 wheels have a 5.84" BS,... that's why you were so close to your wheel tubs.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-23-2014 at 10:29 AM. |
05-23-2014, 10:45 AM | #375 | |
Re: Project: Shiro
