04-29-2014, 11:50 AM | #1601 |
Re: Not Another Rebuild Thread....
Way cool Murph! So the inner script is upside down so that it looks right when the the gate is open!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
04-29-2014, 01:26 PM | #1602 | |
[quote=CRGRS 66;6651724The "Jerry" was intended to be Seinfeld reference, but yes a compliment just the same. Shine on you crazy diamond[/QUOTE] I cannot stand watching Jason Alexander, so I never watched Seinfeld. Which would explain why I did not get your reference, sorry.... Thank you... looking forward to your engine start up too !!! Yeah you caught it, and I took that photo precisely in that perspective just to show that too... The original plan was to make the cut out panel the permanent, welded on one, with the back panel removable, but a lot of factors came into play and the decision was made to do it as it is. Thanks for looking buddy, I should be home (and retired this time, not just visiting) this August !! If you dont have any plans, you should come out to my place for our cook out-camp out weekend (disclaimer: you dont have to cook or camp if you dont want to )
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-29-2014, 01:37 PM | #1603 |
Good eye Jlsanborn!
I sure missed that... As always Murph... Your creativity is beyond words... Well Played Sir!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
04-29-2014, 10:41 PM | #1604 |
So todays update.
I made a backing plate that will enclose the LEDs and help hold them, and the red lens in place. To secure the backing plate I welded 6 of these elevator bolts in. I wish I had come across these a lot sooner, they could have helped me out of quite a few situations where it would have been nice to have a threaded stud emplaced: The Plexiglass got the Night Shades treatment last night, and despite the ever present dust, it came out very even in color, I am quite pleased with it. It is resting on some adhesive half inch foam door and window weather stripping that I stuck to the underside of the backing plate. I used some aluminum skid plate that my neighbor had left over from a project to make the backing plate. I spent some time sanding the cut out panel, working the edges to bevel them some, and round off the four corners. This is after some primer: Here is the tailgate with its second application of bondo. As is my practice, I am again trying to use as little of this stuff as possible, though frankly this is getting the biggest treatment to date on this build. After I sand all this down, I may mix up one more batch and do spot filling with it, as I am never really happy with how this stuff is to work with: That is it for today.... work day and all I just dont get that many hours to lay hands on this bad boy, as I am sure ALL of you can understand !! Rock On dudes, and thanks for looking !!
04-29-2014, 11:02 PM | #1605 |
Rollin' Old Skool
Looks like it's coming together nicely. Keep up the good work!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
05-02-2014, 11:31 PM | #1606 |
Not a lot of photo worthy progress just yet...still working the tailgate.
You know the drill when you do a mod like this... Weld - Grind Welds Weld - Grind MORE Welds Sand Bondo Sand some more More Bondo Sand Sand Sand Primer Sand Apply pinhole filler Sand Primer And that is where I am at now: On a positive note, I REALLY liked how this corner turned out, I just need to go lightly with some sand paper on the other 3 to get them to turn out like this: For me, and my limited skills, this was a tricky mod to do to marry up the different contours involved. All I know for sure though is that I will be really happy when I am past this tailgate milestone. Thanks for looking guys
05-02-2014, 11:43 PM | #1607 |
Gettin' them body workin' skillz all dialed in. Go Murph Go!!!
05-03-2014, 12:04 AM | #1608 |
Keep on keepin' on murph, I envy your "limited" skills, as mine pale in comparison, what will you think of next???
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
05-03-2014, 11:27 AM | #1609 |
Ditto!!!
05-03-2014, 08:47 PM | #1610 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Murph, you simply amaze me with your ideas...in a good way!
"Mark my words", by the time you get your body work close to a completed stage, your skills will have increased to a level that you will start to re-address areas that you had originally worked on, and thought were good enough. And by doing this you will get better at it yet, forcing yourself to re-work areas that you had finished with...Resulting with ALL areas being worked on a minimum of 3 times before all is said & done... "MARK MY WORDS"!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
05-04-2014, 10:45 PM | #1611 |
You keep inspiring McMurphy, excellent progress, skills and imagination.
05-04-2014, 11:25 PM | #1612 | |||
I am fearing my roll pan, because it is next on the list, so I am going to need any and all tricks I have learned so far...
I wish you would post more often, I feel like a crack addict when I read your thread !!! Quote:
About time for an update on yours, yes? I worked up until the whistle went off today, no photos yet, but got a lot of things closer to finished. The in side of the tailgate is ready for masking and paint... mocked up my tailgate release handle, and got the retraction rods in.... positioned the tailgate, and got the new location hinge plates welded in.... and got the cut out side of the tailgate ready for paint. I think I have figured out a quick, cool, and unique set of end caps for the bed rails today too.... will cut those out hopefully tomorrow. The retention arms for the tailgate I am guessing are spring steel ?? I found out that I do not have a drill bit that will scratch them and I need to reposition the mid point piviot (shortend by an inch and three quarters) to get the tailgate perpendicular in relation to the bed sides, and level with the surface of the bed.... So my question for the day is how do I make holes in spring steel ???? I am going to use my plasma cutter unless you guys clue me in !!!
05-04-2014, 11:57 PM | #1613 |
Great job, You have given me some ideas but I'm not gonna be lighting it up like you LOL. I think it's great.
05-05-2014, 10:20 AM | #1614 |
Here ya go Murph,
Don't use the plasma or it will ruin everything. Ask me how I know. Here's a link. http://www.race-mart.com/product.asp...FdGUfgodD5QA2Q Good luck Buddy |
05-05-2014, 10:23 AM | #1615 |
1 thing at a time is progress.
Ok Greg, how do you know.
Alan
Philippians 2:14-16 |
05-05-2014, 01:47 PM | #1616 |
Murph,
Another option is to get a cement drill and sharpen it slightly different for steel. The point on these drills is made from carbide. You need to keep the carbide tip of the drill cooled with liquid as the carbide is only silver-soldered on & the solder will melt at a far lower temp than the carbide itself. We used to do this at work, in order to drill hardened tool steel from time to time. Also, it would be wise to use a drill press, as it takes close to the force of 3 titans when using a hand drill.
05-05-2014, 02:22 PM | #1617 | |||
Most of my stuff has been from looking at other peoples stuff, and then my brain twisting it into something that appeals to me, so I totally get you !! I just hope you share with us what you do Quote:
Wife is going to swing by the local tool outlet and pick me up some drill bits for this... I frankly had no idea they were made of spring steel but after changing drill bits 5 times, and even the drill press could not pierce it, I figured out what I was dealing with (at first I thought it was just dull drill bits LoL) Kinda curious about this too.... Quote:
As a rule I generally oil anything that is thicker than 1/8th inch to keep the drill bits healthy (especially my slugger bits) and I use the drill press every chance I get; much cleaner results that way. Good thing I have other phases of this to work on today, otherwise I would have to make a trip into Fairbanks just for these drill bits, and that takes a large chunk of the day away. Wife can jet out there real quick from post during her lunch break and I can have them tonight when she gets home. I need to get these retention arms adjusted because the receiver latch is getting welded in and I cannot work with them after that. Thanks again for the input guys !! Your comments and wisdom are always welcome
05-05-2014, 10:02 PM | #1618 |
love the tailgate, was kind of what I was thinking you were going to do, just didn't think of you shortening the height! looks really good, nice job for sure!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
05-05-2014, 10:56 PM | #1619 |
Love the mods! Great to hear the end's in sight for you!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
05-05-2014, 11:38 PM | #1620 | |
Either I drive it up onto a trailer done, or I push it up...either way, nothing is getting in my way of escaping Alaska !! It was a swell tour of duty up here, but the swelling has gone down.... ************************************************************************************ So a summary of my weekend efforts... This is me checking the level height for how I want the tailgate to sit, once I get the retention arms under control: A shot of the tailgate down, a peek at what JL Sanborn caught onto... I figured what the heck, I am doing all this mod work anyways, why not make it so the CHEVROLET is readable when the gate is down ??? Got the new height for the tailgate figured out, here is a photo to show: And one of it in ride position: Worked with the back lighting panel some more today, had to resolve an issue I had with some door/window seal I was using as a gasket of sorts that was blocking some of my LED light strips. Then it was more sanding and prepping the tailgate for paint as well....
05-08-2014, 07:37 PM | #1621 |
looks awesome !!! i was thinking maybe you were going to change the gate to open side ways but i see the you are keeping it the up and down
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
05-08-2014, 07:45 PM | #1622 |
Well the masking tape came off the in-side panel of the tailgate today, and I started laying paint on the out-side panel.
A quick peek at what it is coming to: Just a couple shots of it out in the sunshine...you can still see tape glue if you look close enough LoL
05-08-2014, 10:01 PM | #1623 |
Very Nice Sir!!! Very Nice!!!
05-08-2014, 10:48 PM | #1624 |
Looks great buddy
05-09-2014, 10:34 PM | #1625 |
Thanks for the kind words guys !!
You all keep me motivated I took my retention arms to a machine shop today and for $5 they drilled the four holes I needed to adjust the level of the tailgate when down. So far it looks like they are going to be just fine !! Ok, for my tailgate release latch... The stock lift handle type that came off the 85 Sierra required too much operational space for me to adapt to this build, so I had to come up with some other way to get the catch latches to retract. I looked high and low for a "C" ring handle that would lie flat when not in use, but to no avail. I finally settled on a garage door latch that I can lock. Here is that story: I had to shorten the square rod to fit inside the curl of the tailgate frame, not a problem, and drilled a hole for a retainer cotter pin while I was at it. One reason I did not want to go with this idea initially was the handle plus the base made it sit too high/stick out too far from the body of the tailgate and I didnt like that look. Then I got the idea of mounting the base from the inside..... Here is the whole thing in final assembly, and it works like a charm !! After this weekends efforts I will have to remember to shoot a pic with the cut out panel on, (it has wet paint right now) and show just how low profile I was able to get this handle. And yes, I am just a tad proud of this one, as I was not sure at all it would work out.... Actually I am getting a bit too pleased with myself over this entire tailgate so far. Thanks for looking guys, good luck and good progress on your projects this weekend !!
