Old 05-09-2014, 12:47 PM   #1
gunbunny
VIN Number Help
All,
I have an interesting predicament that I just discovered. I bought a 69 C10 Stepside about 6 weeks ago. Matched VIN with title when I bought it. Last night I was looking up the block model and decided to look at the VIN. The VIN inside the drivers door indicates it is a 72 model. Starts out CCE142A. I looked at the VIN on the frame rail this morning and it was 9T834424 which indicates it is a 69. Everything on the truck is 69 from the grill to the metal door inserts. I am confused. It is registered and insured as a 69. Any thoughts? Thanks in advance.
gunbunny is offline   Reply With Quote
Old 05-09-2014, 01:46 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: VIN Number Help
You say you matched VIN with title when you bought it. What VIN did you use?
Do you have the glove box door with the SPID on it? Post up a pic of the door VIN and the SPID (if you have it).
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-09-2014, 02:04 PM   #3
mr48chev
mr48chev's Avatar
Re: VIN Number Help
Any evidence of a cab swap?
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 05-09-2014, 02:57 PM   #4
gunbunny
Re: VIN Number Help
Yes I matched the Title to the VIN inside the drivers door. Don't see any evidence of a cab swap. It looks like a 69 cab to me. The guy I bought it from only had it about a year. Searched the VIN and I saw where the guy he bought it from was selling it. I far as I know this all could have been done back in the 70's! It has been painted in the last 3 or 4 years and I am positive the data plate was removed, jambs painted and then riveted back on. Nothing in glove box...it is new.
1969 White Chevy C10 Stepside. 383 Stroker.
Old 05-09-2014, 02:57 PM   #5
boostedc10
boostedc10's Avatar
Re: VIN Number Help
I don't understand how you could have matched the VIN when you bought it and it changed?
The frame VIN is not the easier of the 2 to look at so I am assuming you matched the cab VIN.
Technically if the title is for the VIN plate on the cab you should be ok, but if it doesn't you may be SOL.
Even if the title matches the VIN plate on the cab I would still question the seller about the cab swap.
boostedc10 is offline   Reply With Quote
Old 05-09-2014, 03:01 PM   #6
gunbunny
Re: VIN Number Help
It didn't change. I matched the VIN on the title with the CAB VIN. I didn't decode the VIN at the time or do anything but match it to the title. I was research the small block version that I have last night and decided to decode the VIN and that is when I discovered that it was a 72 VIN. I checked the frame VIN this morning and it is a 69 VIN. It was sold to me as a 69.
Old 05-09-2014, 03:10 PM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: VIN Number Help
The VIN has been swapped, wrong rivets. If it is registered and tagged already you should be ok. Different story when you go to sell it.
Old 05-09-2014, 03:12 PM   #8
gunbunny
Re: VIN Number Help
Thanks. That is what I assumed.
Old 05-09-2014, 03:15 PM   #9
Spartan
Spartan's Avatar
Re: VIN Number Help
No rosettes. No dice. Imho
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 05-09-2014, 03:27 PM   #10
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: VIN Number Help
So the truck is titled as a 72?
Old 05-09-2014, 03:32 PM   #11
boostedc10
boostedc10's Avatar
Re: VIN Number Help
This is where I was confused too. I thought it was sold as a 1969?
Does the title match the plate?
Old 05-09-2014, 03:36 PM   #12
gunbunny
Re: VIN Number Help
Titled as a 69.....with 72 VIN.
Old 05-09-2014, 03:46 PM   #13
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: VIN Number Help
Wow. Looks like you'll be keeping this one forever......or trying to get your money back.
Old 05-09-2014, 04:54 PM   #14
leddzepp
Moderator
leddzepp's Avatar
Re: VIN Number Help
When you bought it was it inspected by your DMV? I doubt it because if they did the vin rivets are a dead giveaway. Its probably been registered as such for a very long time, I wouldn't even worry about it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-09-2014, 11:37 PM   #15
gunbunny
Re: VIN Number Help
No not inspected by the DMV. They confirmed VIN with title and that was it. Trying to find out who did that part of the restoration but that was about 3 owners ago. Have never ever before decoded VIN before I bought something. Won't happen again. Thanks everyone.
