Old 05-11-2014, 07:19 AM   #1
Nev68
Nev68's Avatar
1956 dash gauges voltmeter?
Has anyone converted a standard TF dash to house a volt meter?
I'm not really sure I need an ammeter but can see some value in a volt meter.
Can I replace the ammeter with a voltmeter (obviously need some different graphics as well) ?
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 05-11-2014, 07:38 AM   #2
lowrodderchev
lowrodderchev's Avatar
Re: 1956 dash gauges voltmeter?
Do a search believe it was ogre that did 1 with a $10 AutoZone gauge
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 05-11-2014, 07:39 AM   #3
lowrodderchev
Looks pretty good to use the stock face
Old 05-11-2014, 10:54 PM   #4
_Ogre
_Ogre's Avatar
look in my build, i did a write up on converting a 2'' volt gauge into the stock cluster
i kept the stock face and needle. bent the needle to be in the center at 13 volts
if you like what i did post up a comment to move my build from page 10 oblivion
shop air compressor timer
Old 05-12-2014, 05:32 AM   #5
Nev68
Nev68's Avatar
Thanks I'll check it out
Nev
