1956 dash gauges voltmeter?
Has anyone converted a standard TF dash to house a volt meter?
I'm not really sure I need an ammeter but can see some value in a volt meter. Can I replace the ammeter with a voltmeter (obviously need some different graphics as well) ? ![]()
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
Re: 1956 dash gauges voltmeter?
Do a search believe it was ogre that did 1 with a $10 AutoZone gauge
Looks pretty good to use the stock face
look in my build, i did a write up on converting a 2'' volt gauge into the stock cluster
i kept the stock face and needle. bent the needle to be in the center at 13 volts ![]() if you like what i did post up a comment to move my build from page 10 oblivion ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Thanks I'll check it out
