05-11-2014, 01:00 PM | #1 |
Replacing gauge cluster with aftermarket gauge cluster?
So I took out my original gauge cluster. The bundle of wires that plugs into the back of the factory gauge cluster? Do I take all that out or just cut the conector off and figure out where all the wires are running and connect the new wires to them? There sure is a mess of wires under the dash? Thanks for any help!
05-11-2014, 02:37 PM | #2 |
Re: Replacing gauge cluster with aftermarket gauge cluster?
You could tap into the wires & leave the connecter on there. If you ever wanted to go back to stock you could.
05-11-2014, 04:03 PM | #3 |
Cluster King
Here is a diagram of the connector and where each wire goes and color. It should help you determine what is what.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
05-11-2014, 06:31 PM | #4 |
Old member
That's what I did. Just in case I ever go back to orignal but I doubt I ever will.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-12-2014, 10:31 AM | #5 |
05-12-2014, 01:14 PM | #6 |
saved for that diagram. Doing mine soon. Thanks!
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
