05-12-2014, 12:43 AM | #1 |
How to go about this?
Well I ended up getting a new oil pressure gauge for my truck. And it seems that I'm going to have to cut a hole in the face of the old oil pressure gauge, in order to properly mount the new one.
How should I do that? I die grinder is overkill. And a dremel would take forever. But maybe it should take forever. So that its done right the first time. Is there an easy way? |
05-12-2014, 08:34 AM | #2 |
Robert Olson Transport
Re: How to go about this?
id use the dremel
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
05-12-2014, 09:11 AM | #3 |
Is this a factory or aftermarket gauge? I cant see having to do any mods with a factory replacement gauge.
John 82 Chevy Silverado 350ci/TH350 |
05-12-2014, 04:25 PM | #4 |
Autometer. Gotta cut that hole in the factory one to make everything line up easily and correctly. Otherwise I've got no way to tell if its too far forward, or backwards. Until its already mounted and then with all the work you put into doing that, its too late.
05-12-2014, 05:34 PM | #5 |
Maybe you could go all out like this. Bigblock73 (Jeff) sells the kit or at least he used to.
http://67-72chevytrucks.com/vboard/s...d.php?t=513790
05-12-2014, 07:09 PM | #6 |
I used a hole saw once. It worked pretty good. Just make sure the hole saw you use is the same outside diameter as the gauge diameter because a hole saw will almost always make a hole just a touch bigger.
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
