Old 01-04-2014, 04:20 PM   #26
Razor454
Razor454's Avatar
Re: Project remove my sunroof
Thanks Scott, figured it was time to get it done.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi
1997 C2500 Ext Cab 5.7 Liter
1955 3/4 ton 1st series w/ 235 straight six Sold it
Razor454 is offline   Reply With Quote
Old 01-04-2014, 04:29 PM   #27
rob32472
You could always weld the seem solid across the back..... IMHO it looks better that way.
rob32472 is offline   Reply With Quote
Old 01-04-2014, 04:33 PM   #28
westong
Originally Posted by 69SWB4X4 View Post
I am about to do the same repair on my truck. My thought was to flange the sunroof opening and cut a patch from my donor skin. Could also flange the patch if room is an issue.. On the inside I plan to use dyna mat in the old sunroof hole and add a headliner.. Thoughts??
I did that kind of repair on a 1966 chevelle that someone put a sunroof in. It worked great i drove the crap out of it and never had any problems. The car has been gone for a few years but i would like to think it held up well. Just take lots of time welding it in as u dont want to warp the thin sheetmetal.
westong is offline   Reply With Quote
Old 02-03-2014, 10:38 PM   #29
Razor454
Razor454's Avatar
Quick update: Stripped and sanded the paint off the donor top and fitted it in place. Will epoxy paint the inside once it warms up.
Old 02-03-2014, 10:56 PM   #30
Elliot949
Elliot949's Avatar
Very Nice...
Elliot949 is offline   Reply With Quote
Old 02-03-2014, 11:22 PM   #31
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Very nice, you make it look easy.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 02-04-2014, 08:47 PM   #32
Razor454
Razor454's Avatar
Thanks guys
Old 02-04-2014, 08:56 PM   #33
Lou Boffa
Lou Boffa's Avatar
mad skills!
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 02-04-2014, 09:07 PM   #34
chrisestes
Thumbs up Re: Project remove my sunroof
nice job on the roof!!!
chrisestes is offline   Reply With Quote
Old 05-13-2014, 01:53 PM   #35
Razor454
Razor454's Avatar
Ok, so I finally got some time to finish the roof. I stripped and primed the inside of the roof, then installed the original insulation inside before buttoning it up. I ended up welding the front lip of the roof and using 3M panel adhesive on the back edge. I clamped it all together and let it sit over night. The results turned out great.
Old 05-13-2014, 02:28 PM   #36
cericd
cericd's Avatar
Congrats! Looks way better without the sunroof hole.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 05-13-2014, 03:59 PM   #37
swamp rat
swamp rat's Avatar
Great work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-13-2014, 10:38 PM   #38
Razor454
Razor454's Avatar
Thanks, I only have to smooth out a small dimple in the rear of the panel. Which I should have done by this weekend.
Old 05-13-2014, 11:29 PM   #39
CUSTOM/10
CUSTOM/10's Avatar
Awesome job !!! I also don't like sunroofs in theses trucks ! Great workmanship !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 05-14-2014, 04:54 AM   #40
leftybass209
leftybass209's Avatar
Wink Re: Project remove my sunroof
That's some good work! Congrats, so when's the new sunroof going in?
leftybass209 is offline   Reply With Quote
Old 05-14-2014, 09:39 AM   #41
Mr Chevorlet
Rusty Nuts
That was a nice job well done!
Larry
Mr Chevrolet
