Closed Thread
Old 05-10-2014, 02:56 PM   #3426
OrrieG
OrrieG's Avatar
Re: What Did You Do With Your Truck Today ?
looks relatively easy, 58-59 fenders have 5-6 more bolts on the inside to the grille.
OrrieG is offline
Old 05-10-2014, 05:41 PM   #3427
Russell Ashley
Russell Ashley's Avatar
It wasn't too bad, I just didn't want to do it, LOL. I was hoping to get the new suspension installed without having to, but now that it's off I will take care of a few things that I can get to easier.
Russell Ashley is offline
Old 05-10-2014, 05:45 PM   #3428
Russell Ashley
Sorry, double post.
Old 05-10-2014, 06:48 PM   #3429
Rednek13x
Rednek13x's Avatar
worked on removing rivits to remove some cross members. going to need to track down a bigger air hammer!
Rednek13x is offline
Old 05-10-2014, 08:34 PM   #3430
lowdownstar
big guy
lowdownstar's Avatar
Working on door gaps, trying to make everything fit. Alot more work and i thought it was going to be lol
Ray
lowdownstar is offline
Old 05-10-2014, 08:43 PM   #3431
OrrieG
OrrieG's Avatar
What AC system are you running (looks like VA)? Did you have to R&R the radiator X brace and use shims to stand it off of the support when you reinstalled?
OrrieG is offline
Old 05-10-2014, 08:49 PM   #3432
OrrieG
OrrieG's Avatar
What I learned today, maybe will help someone else.
1. TH350 cooler pump does NOT have enough back pressure to fill a temp gauge fitting tilted above horizontal. Pulled the temp bulb and it was dry, strong armed the fitting below vertical and it started leaking, so hopefully that will solve the no worky problem. Did test the gauge when I had the bulb out its fine.
2. A tach power wire needs to come from a switched circuit, if it is on a non-switched circuit it will drain you battery in about a week. Murphy's law dictated that the last fuse out of 21 I pulled was the problem one. Anyway, now no more power draw, tach manf offered no reason it pulls power when not running.
OrrieG is offline
Old 05-10-2014, 09:13 PM   #3433
Russell Ashley
"What AC system are you running (looks like VA)? Did you have to R&R the radiator X brace and use shims to stand it off of the support when you reinstalled?"
Yes, it is a VA system. I moved the cross brace out one inch. I cut some one inch long pieces of one inch diameter round aluminum rod and chucked them in my lathe and drilled the hole through the center. You could just stack washers to get the length you need.
Old 05-15-2014, 04:49 PM   #3434
OrrieG
OrrieG's Avatar
Thanks, that is what it looked like. Opened my mail box today and all the hose fittings arrived. Was going to just order hoses from VA but when I measured would have had a bunch of extra length looping around the inside.
OrrieG is offline
Old 05-16-2014, 08:19 AM   #3435
Russell Ashley
Orrie, I bought the VA hose kit and it didn't come with some of the ends on the hoses. You cut the hoses to fit your installation and marked the orientation that you wanted the ends to be and VA would compress the ends on for you. I am fortunate that I have a VA dealer near me and they did mine for me.
Old 05-16-2014, 08:50 AM   #3436
Russell Ashley
Removed my front suspension in preparation to installing my Scott's front end. I was working by myself so I had to take it apart in pieces that I could handle. Today I want to remove the spring and shock brackets from the frame.
Old 05-16-2014, 01:17 PM   #3437
OrrieG
OrrieG's Avatar
I looked at that option, but the ends that came with it would not work. I will post photos of the hoses when I get them fabbed so you can see what I am doing. I have access to a crimper so doing three more connections is not a big deal. Our local VA dealer likes to bend folks over on shipping and handling fees and doing hoses. For what he wanted to crimp mine I could buy a good quality crimper.
OrrieG is offline
Old 05-16-2014, 03:57 PM   #3438
Russell Ashley
Look at this link: You are probably aware of this but just in case.
http://www.vintageair.com/Instructions2013/900002.pdf
Make sure you have the right crimper for your fittings.
Old 05-16-2014, 04:01 PM   #3439
OrrieG
OrrieG's Avatar
Good to know, thanks for watching out for me! The tools I am getting are an automotive ac set with the right dies, the person used them on his AC with success.
OrrieG is offline
Old 05-16-2014, 10:14 PM   #3440
BADAZ chevy guy
BADAZ chevy guy's Avatar
New ball joint and windshield washers. Now she's ready for inspection, Monday!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline
Old 05-16-2014, 10:52 PM   #3441
SCHRUMGMC
SCHRUMGMC's Avatar
Bought some more parts today
Making some progress on the '59
Costed me $82 sweet lord these parts are pricey
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 05-18-2014, 01:27 PM   #3442
OrrieG
OrrieG's Avatar
Got the AC compressor clutch and fast idle solenoid wiring sorted out. Running that "last wire" after everything else is done is a pain....
OrrieG is offline
Old 05-18-2014, 01:44 PM   #3443
brikar
brikar's Avatar
Installed the spare tire carrier my son built me
brikar is offline
Old 05-18-2014, 07:59 PM   #3444
dubie
dubie's Avatar
i painted mine today
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 05-18-2014, 08:19 PM   #3445
FarmerSid
FarmerSid's Avatar
Awesome brikar! Talented son.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline
Old 05-18-2014, 08:23 PM   #3446
FarmerSid
FarmerSid's Avatar
They are but try reproducing one. They know they have us by the short and curlies.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-18-2014, 08:25 PM   #3447
FarmerSid
FarmerSid's Avatar
So.............you painted on a dent dubie?
C4 IFS & D44 IRS
5.3 HO L33
Old 05-19-2014, 06:04 AM   #3448
Nev68
Nev68's Avatar
Nice work.
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline
Old 05-19-2014, 09:31 AM   #3449
brikar
brikar's Avatar
yes,I'm very proud of him,he's a B-pressure welder and he loves building and fabricating, here's his toy.
brikar is offline
Old 05-19-2014, 10:46 AM   #3450
dubie
dubie's Avatar
building a shop truck here Farmer Sid, it's all going to work into the final product.
dubie is offline
Closed Thread
