Old 05-16-2014, 09:48 AM   #1
CUSTOM/10
CUSTOM/10's Avatar
Re: Brake Hoses
Hey Brian;
Not sure what you consider to be economical but I just ordered all new SS braded flex hoses for my 72 with a 2.5" lift from Inline Tube. I'm also putting disc brakes all around, so I went with 10 mm banjo fittings for new style calipers. It was about $200. They may not know all the stock lengths of hoses, so you may want to measure yours and have an idea how much longer you need the new ones. You can jack up your truck, ( Letting the axle droop ) and measure what you need leaving a little extra so the hoses never get pulled tight.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 05-16-2014, 10:13 AM   #2
BrianG
BrianG's Avatar
Re: Brake Hoses
Originally Posted by CUSTOM/10 View Post
Hey Brian;
Gary
I'll check Inline Tube out. I have heard them mentioned on this board before.
One solution that I was looking at was the Skyjacker ones. "Skyjacker (FBL16) 3"- 4" Stainless Steel Brake Line - Pair" They are available in a pair (the FBL16) or singular (RBL12) They sell for about $105 for the front pair and around $45 or $50 for the back. They have an option for either the 2(3) - 4" lift or 6 - 8" lift. I've got the stock brake hoses now with a 4" lift. I've never had an issue with them. I'm wondering if the 6 - 8" hoses would maybe be too long. I'd have about $160 into these, but wondered if there was an even cheaper alternative. I don't really need the braided stainless hoses.
BrianG is offline   Reply With Quote
Old 05-16-2014, 10:30 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
Re: Brake Hoses
There are lots of places you can get the stuff you need. I didn't shop around, I was ordering SS brake tubing and some other stuff so I just added the hoses in knowing I was going to need them soon.
I'm sure you can do better price wise, I just threw it out to you because I just ordered them, they’re getting delivered today
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-16-2014, 11:09 AM   #4
dieseldawg142
dieseldawg142's Avatar
Re: Brake Hoses
have skyjacker 8" brake lines on my crew.
$160 is nothing really when you consider it's whats stopping you. you really dont want to cheap out on b.lines.
the braided stainless lines will take way more use & abuse than rubber, & they will give your brakes a better more consistant feel i found
if you buy f&r lines, i got banjo's & brake block with mine
dieseldawg142 is offline   Reply With Quote
Old 05-16-2014, 11:31 AM   #5
BrianG
BrianG's Avatar
Re: Brake Hoses
Sorry, I don't want to sound ignorant, but I think I will anyhow....
"if you buy f&r lines, i got banjo's & brake block with mine"
What do you mean? :-)
The banjo end is what would be stock with a disk brake setup correct? I have a stock brake line setup now, would the skyjacker hoses work as is, or would I have to add additional parts?
Old 05-16-2014, 11:47 AM   #6
CUSTOM/10
CUSTOM/10's Avatar
Re: Brake Hoses
The banjo or your final connection to the calipar changed around 79 to a 10 mm banjo type connection ( This is the fitting at the calipar end of your flex hose ). Prior to that I believe the connection was 7/16 ? If your calipars are stock, you would have the 7/16.
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-16-2014, 11:57 AM   #7
CUSTOM/10
CUSTOM/10's Avatar
Re: Brake Hoses
So basically you need to know what connection is on the calipers that your going to use and match the flex hose to that !
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-17-2014, 08:43 AM   #8
BrianG
BrianG's Avatar
Re: Brake Hoses
Great info to know! Thank you!
