05-17-2014, 05:53 PM | #1 |
Alignment issues?
Anyone with a 5 or 5.5 drop in the front have any alignment issues. I talked to ECE and they said you can't align these trucks with more than a 4.5 drop. Just curious before I order all my parts. Thanks.
05-17-2014, 06:19 PM | #2 |
Re: Alignment issues?
If you do 4.5 inch spring drop only then you wont be able to align it. A combination of spring and spindle drop and you will be fine.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-17-2014, 06:23 PM | #3 |
Ok that's what i thought. Maybe I was not clear when I spoke with them. I plan on a 2.5 spindle and 3" spring. Thanks for the reply.
05-17-2014, 07:51 PM | #4 |
Watch out for your cornhole !
It will align just fine as long as the rest of your suspension is good and not sloppy.
