Old 05-18-2014, 10:42 AM   #1
Sean C
Painting the Dash (still in the cab)?
Anyone ever do this? I figure if I pull the seats and tape everything up this shouldn't be a problem. Any special tips as far as sanding the dash like covering vents and what not?
Sean
Sean C is offline   Reply With Quote
Old 05-18-2014, 10:57 AM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: Painting the Dash (still in the cab)?
I'd pull the window and seal out. It'll make things easier. Far as I know the dash is bolted in.
Old 05-18-2014, 12:48 PM   #3
Sean C
I believe there are several spot welds along the seam of the windshield. I'd rather not drill them out
Old 05-18-2014, 01:35 PM   #4
oem4me
I did it years ago with no probs. Masking will take a lot of time to do it properly, but it'll be worth it. Cutting corners and saving a few hours while masking will show in the results ...forever. You could pull the windshield, but it's not absolutely necessary. Depending upon the type and size of spray gun you use, getting down in close where the dash and glass meet will be the biggest challenge, and naturally, ANYTHING you don't want painted will have to be removed or covered.
Old 05-18-2014, 01:47 PM   #5
unique760
yeah I took out the seat and carpet when I painted my dad's 66. as well as the cluster and heater components and painted them outside the cab. I also took out the heater vents and painted them a different color. the only trouble is sanding the lip between the windshield rubber and dash, I just pushed the sandpaper a little under the rubber and sanded like that, other than that it was smooth sailing with the prep. these are before and after pics
unique760 is offline   Reply With Quote
Old 05-18-2014, 05:34 PM   #6
Sean C
Awesome!! Thanks for the pics amigo and to the others who responded! I'll put up some pics when I'm finished. I'm pretty excited for this one
Old 06-02-2014, 11:08 AM   #7
Sean C
I think mine turned out pretty alright! Thanks again fellas
http://67-72chevytrucks.com/vboard/s...=1#post6703083
Old 06-02-2014, 11:24 AM   #8
1963c-10
1963c-10's Avatar
Don't think you'd have the same success with a 60-63 style dash due to the shape....but nice job.
1964 Short bed trailer
Old 06-02-2014, 12:54 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'd have no issue doing it without the windshield in. With it in place, I wouldn't even bother, as I wouldn't be happy not being able to angle the gun to both sides.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-02-2014, 04:58 PM   #10
Ronw435
Ronw435's Avatar
Any threads on removing the windshield?
Ronw435 is offline   Reply With Quote
Old 06-02-2014, 07:32 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Old 06-02-2014, 10:27 PM   #12
terbronco7
terbronco7's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1401762434
terbronco7 is offline   Reply With Quote
Old 06-03-2014, 08:07 AM   #13
Ronw435
Ronw435's Avatar
BR3W City, that was not quite the answer I was looking forward but I can share your frustration........lol.
Old 06-03-2014, 08:28 AM   #14
1963c-10
1963c-10's Avatar
Easiest way is to cut the gasket from the inside while having else work from the outside. Should come out with minor work, just make sure to catch the glass so it doesn't fall out.
Old 06-03-2014, 09:06 AM   #15
Ronw435
Ronw435's Avatar
Thanks 1963c-10. I guess the worse thing that can happen is breaking the windshield, but with Deep Ellum Auto Glass being close by it sounds like an alternative.
Old 06-03-2014, 04:25 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
In seriousness, the only advice I can give is that;
you might as well factor a new windshield into budget, and then be happy if you don't need it. When taking them out, its really common to either cut the gasket (eliminating the "press" fit), or to use those metal hook deals. On an older windshield, its possible to chip the outer lamination, and when you go to reinstall; craaaack.
They can be removed, but its gotta be in perfect shape, and removed in a way preventing chipping on the edges. If those things are not an issue, then it should come out and be able to be reinstalled later without any more headache than usual.
Old 06-03-2014, 04:45 PM   #17
1963c-10
1963c-10's Avatar
Although there was a member here who decided it was easier to kick the windshield out from inside the cab.....but he was going to replace the windshield anyways...
Old 06-03-2014, 06:42 PM   #18
terbronco7
terbronco7's Avatar
BR3W CITY is correct one chip and crackkkkkkk... I broke 2 new ones installing mine 3rd time was the charm.http://67-72chevytrucks.com/vboard/a...1&d=1401835228
Old 06-09-2014, 05:35 PM   #19
66BigBackWindow
Thanks for the pics. I have a 66 that a previous owner primered the entire inside of the cab. Including the data plate on the drivers kick panel. I really want to see fawn back in there some day.
66BigBackWindow is offline   Reply With Quote
Old 06-09-2014, 08:24 PM   #20
vin63
It's Better With Nitro
vin63's Avatar
I just finished painting the interior. I removed the windshield so I could get a good consistent spray pattern on the top of the dash and A-pillars. I cut the weather strip around the glass with a utility knife with new blades, and tilted the windshield out (extra set of hands helps here). I removed a dash out of a parts cab once, but I would not want to try and re-install it after it was painted. It was a pain to remove cutting all of the welds...I can't imagine trying to install it without dings or chips.
Primer...
...base coat...
...satin clear...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
