Old 05-16-2014, 09:29 AM   #26
Hart_Rod
Hart_Rod's Avatar
Re: Uppwe A/C mounts for LS
Originally Posted by fastpace View Post
The pictures I posted are the Holley AC bracket, I just stayed with the original alternator bracket.
My bad, I thought that was a Dirty Dingo or Kwik bracket. It looks like you used a SD8 compressor. I used the SD7 which reduces the footprint somewhat.
Hart_Rod is offline   Reply With Quote
Old 05-16-2014, 10:05 AM   #27
solidaxel
solidaxel's Avatar
Originally Posted by Wasted Income View Post
The only difference is that most (all?) of the 2500 pump are hydroboost pumps. They are externally the same, except for a 2nd oil return to the reservoir.
My 5.3 in my 78 has a second return line, I wondered what that one went to!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-16-2014, 11:28 AM   #28
Wasted Income
Boosted Member
Wasted Income's Avatar
Originally Posted by Hart_Rod View Post
Those aren't Holley brackets, these are:
Wow, that hangs the accessories WAY out there.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-16-2014, 11:39 AM   #29
Hart_Rod
Hart_Rod's Avatar
, I think the picture makes it look further than it really is. Here's one of my 68.
Old 05-17-2014, 10:32 PM   #30
Blackpony
Blackpony's Avatar
Here is my setup from lsbrackets.com. you can also run a sanden compressor with this bracket. I just chose the r4 to keep it more compact.
Blackpony is offline   Reply With Quote
Old 05-18-2014, 09:14 AM   #31
dayj1
Originally Posted by solidaxel View Post
We changed to a 2010 Camaro pump but that did not work out with alignment of crank shaft and power steering pump, so went back to the truck pump
It sounds like you're saying that the belt track of the 2010 L99 Camaro pump didn't line up with your truck accessories? Do you have any pictures or the part number off your Camaro pump? I'm just wondering what's going on as I recently put a Camaro pump on a 4.8 that I'm working on and it was a perfect fit with the truck parts.
dayj1 is offline   Reply With Quote
Old 05-18-2014, 05:23 PM   #32
solidaxel
solidaxel's Avatar
Well, now you have me wondering what they sold me!
I will dig out the invoice (sure) and get the part number.
All I remember is that the water outlet was moved to the drivers side and hit the Alt. brakt. as I remember, but thet was two weeks ago!
LS 3 4L70E
Old 05-18-2014, 06:11 PM   #33
dayj1
It should have been GM part number 19207665 or Delco part number 251-734. Cheapest place I could find it was Amazon for $123 with free shipping.
Here's a couple of pics of my 4.8. I have a mish-mash accessory drive, because I wanted to run the car intake, but that's the truck balancer in the pic and I tried the Camaro pump with the truck alternator and power steering bracket. It worked just fine with that, too. In my case it was interference between the idler pulley on the truck bracket and the TB that caused me to go to the setup in the pictures.
