01-02-2004, 04:58 PM | #1 |
I Hate Mice!!!!
This is after three nights in the barn with the carb off the intake. Luckily I happened to be installing an edelbrock manifold and not just messing with the carb or something. I found a good sized stash of acorns in five out of eight intake ports. I am worried that I might have to pull the heads to make sure that one of the little bastiches didn't squeeze through on open intake valve and die in the cylinder.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
01-02-2004, 05:22 PM | #2 |
Beer Power!!!!!!!!!!
Man that's bad luck!
Rather be fishin' |
01-02-2004, 05:24 PM | #3 |
I do battle with mice all the time. I wish that there were a way to gas them!
I have three cats and I set traps all the time in addition to rat poison, (in areas where the cats can't get to), and still they are around. I put screens in the cowls of the trucks and this seems to keep them out of the truck cabs anyway. It is a constant fight! Jim |
01-02-2004, 05:44 PM | #4 |
English Chevy Owner
We used to rent a barn on a farm near to a grain store to work on cars in. The rats around there were the size of cats and the concrete floor of the barn was hollow with rat burrows underneath. Every so often we used to stick a garden hose up an exhaust pipe, stick the other end down a rat hole and leave the engine running for a while, exhaust fumes used to come up all ver the place, kept the little buggers numbers down a bit and gave us some satisfaction anyway!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
01-02-2004, 06:01 PM | #5 |
Wiseass secured himself a BAN
I would have put some duct tape over the ports before I let the engine set up for 3 months. live and learn
01-02-2004, 06:05 PM | #6 |
DON'Y WORRY.....if one's in there...he will be out the exhaust pipe
in seconds one of those little dudes won't stop that engine |
01-02-2004, 08:13 PM | #7 |
Must be a smallblock "mouse motor".
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
01-02-2004, 09:08 PM | #8 | |
01-02-2004, 09:20 PM | #9 |
I have mice and rock squirrels up here in the mountains.
I put in boxes of Decon and I put a tray of moth balls under the hood and in the cab. It helps but it's a constant battle, it does not help that I don't drive the truck in the winter.
1970 Chev C20, 2wd, LB, 350 4BBL, muncie 4spd, 4:10 limited slip. 2002 Chev 2500HD 8.1L Allison, 4X4. 1996 Chev S10 Blazer, 4X4. 2006 Jeep LJ Rubicon |
01-02-2004, 09:49 PM | #10 |
Lippy,
I like your idea! jim |
01-03-2004, 12:43 AM | #11 | |
LOL Reminds me of that commercial with Bret Favre...I would have double bagged it....LOL
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! Last edited by 86SILVERADO; 01-03-2004 at 12:47 AM. |
01-05-2004, 04:57 PM | #12 |
Another trick is to put a couple of those Christmas tree airfreshners in the cab. A friend of mine learned this trick from a salvage yard owner. It seemed that the wrecks with the trees didn't have mice and the ones without did. I have done this with a couple of airplanes that do alot of setting and on the last annual there were no mice in the one that is a flyer.
Justin |
01-05-2004, 09:34 PM | #13 |
PROJECT 7DEUCE
Bummer that can't be good???? KILL EM ALL
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-05-2004, 10:20 PM | #14 |
And I feed the poor little things at work.......
01-05-2004, 10:25 PM | #15 |
Life is Good !
good thing u noticed it !
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
01-06-2004, 12:17 AM | #16 |
No kidding. I just put 2500 into this motor. I don't think acorn mash in half the cylinders would have done it much good.
01-06-2004, 12:36 AM | #17 |
GM ONLY BABY!!!
Here's a new one for you guys. Put in a couple bars of Irish Spring soap. I think it works pretty good. I tried moth balls in my 66 Chevelle when it was in storage and it didn't work. Those damn mice chewed up the original interior in the Chevelle. My girlfriend told me to use the Irish Spring soap and it has worked pretty good so far. I would put a bar in the engine compartment and 2 inside the truck. I put 4 in the Chevelle and it seemed to work. Try it. What have you got to lose?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
01-06-2004, 02:33 AM | #18 |
I have actually heard of the irish spring trick as well as the air fresheners. Also scented dryer sheets are supposed to work pretty well. I have never tried any of these but I will probably not be driving the dump much this winter so I may give some of them a shot.
01-06-2004, 03:42 AM | #19 |
Black 72 Chevy
I have two 6 month old cats and so far they done a good job in taking care of the mice. 7 confirm kills.
72 Chevy, SWB, 350engine, TH400 |
01-06-2004, 09:32 AM | #20 | |
Get a bar and a couple of old Cool Whip or similar containers. Shave the bar down with your pocket knife. Put the shavings in the container(s). Then put the containers in each compartment. In my cars I put one on the front floor, one in the back, and one in the trunk. Plus come spring your boat/car/truck has that "clean Irish scent".
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
