Old 05-20-2014, 09:14 PM   #1
fluffyfreak
half ton to 1 ton, can it be done?
I hVe a 86 half town C10 reg cab longbed, im wondering what the differences in thd frames are between the half ton and 1 ton frames are, and will the suspension components fit?
fluffyfreak is offline   Reply With Quote
Old 05-20-2014, 11:39 PM   #2
mrolds88
Re: half ton to 1 ton, can it be done?
There is a good bit of difference between the 1/2 and 1 tons as far as heft. If you are looking to swap all the suspension you may run into a bit of an issue with the rear springs. The 1/2 units are 52 and the ton units are 56 long. I would swap the cab onto the ton frame if it were me. Might as well get all the use out of the suspension and axles.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-20-2014, 11:56 PM   #3
71swb4x4
71swb4x4's Avatar
I believe the frame is thicker steel and larger (taller). I know on 67-72's the 3/4ton and 1 ton are taller.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-21-2014, 01:27 AM   #4
fluffyfreak
Ok thanks guys, was gonna convert my LB to a dually, but if the weight of a gooseneck will still be too much for the frame then ill skip that
Old 05-21-2014, 01:51 AM   #5
chevymadness
Finally someone that wants to do big things with a 2wd.I have the same truck and was asking 1 year ago exactly same stuff and essentially how to convert to 4x4 and I was laughed out of the forum.Anyway you will need to do a lot of stuff like weld a crossmember from what I remember on the front etc etc.Essentially you would want to have a 4x4 so you can lift the damn thing otherwise don't waste 1-2 thousand.Im just going to throw a axle on the front with some leaf springs and call it a day like I heard some guy did on another website for 300$.
1982 chevy silverado
It's all about original guys original let me say again original.
chevymadness is offline   Reply With Quote
Old 05-21-2014, 02:43 AM   #6
andrewmp6
Yeah the frame is taller and thicker.If your trying to tow more with your truck its cheaper to buy a dually.Legally your door sticker says how much you can tow and D.O.T. goes by that number.If you get caught pulling more then that number its a nice fine and you gotta drop the trailer and come back with a bigger truck.
Old 05-21-2014, 03:04 AM   #7
bucannon
Salty Sailor
bucannon's Avatar
ive swapped alot of 3/4 ton suspension stuff on my C10. the 1 ton stuff is heavy duty for sure, but what are you planning on towing?
I believe you could weld in crossmembers and stiffen the frame. Add beefy springs with some air ride. I would bet that you could pull a gooseneck without any issues as long as your drivetrain was up to the task. and it would be a great build thread to read, Just Sayin!
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 05-21-2014, 07:35 AM   #8
Keith Seymore
Keith Seymore's Avatar
That's because it is essentially a different model.
The differences are so significant that it would be like converting a log cabin into a plantation home (or a Ford into a Chevy). Anything can be done given enough time, money and/or talent - but that doesn't mean it is recommended.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-21-2014, 07:48 AM   #9
chevymadness
How much weightis the damn good neck trailer is it all 6500 pounds cants a c10 pull that much if it can't I'm going to be pissed with this truck.I want to buy a boat.
Old 05-21-2014, 10:37 AM   #10
SCOTI
SCOTI's Avatar
How big of a boat? C10's pull boat trailers all the time.... A lwb C10 (86 model) is prob around 4k pounds w/a 1/2 ton capacity so about 5500lbs.
C30 equipment can be swapped over. But, the strength of the taller, heavier gauge steel frame of a C30 won't be there on your C10 which limits the ability to safely tow/haul a similar load.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-21-2014, 11:10 AM   #11
Keith Seymore
Shoot. During times of desperation I've pulled my enclosed Haulmark with Lil Red (approx 7500 lbs with the car in the trailer). But - I would not recommend this, as the truck is a V6/manual trans, which made it a bit balky.
...but this is how we rolled back in the day (every weekend). Car + trailer + stuff is about 5000 lbs.
Nooooo problem. In fact, this is the rig I used when we moved from Detroit to Phoenix in 1990.
K
1979-1986
1986 - 2019
Old 05-21-2014, 03:30 PM   #12
bucannon
Salty Sailor
bucannon's Avatar
I have towed a trailer loaded down with 8000 pounds of concrete debris with mine. I didnt go anywhere fast but never had any issues
Savannah, Georgia
Old 05-21-2014, 04:43 PM   #13
SCOTI
SCOTI's Avatar
We all know if the load exceeds the weight of a tow vehicle that was not engineered for such loads, bad things can (and do) happen.
Occasional duty is ok. Repeat or constant use w/big loads & a better suited rig should be utilized as they have the rails/frame work to support the task.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-21-2014, 09:30 PM   #14
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Wish you were closer! I have a complete rolling dually chassis I'm about to scrap.
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 05-21-2014, 10:34 PM   #15
fluffyfreak
Well damn mr chevy!! That does suck
Old 05-21-2014, 11:50 PM   #16
mrolds88
FF, check with Anchorism. He has a dually that he is parting/ parting with. Might be the ticket for you. He's fairly close too!!!! (check out the 73-87 for sale section)
93 K2500 xcab 6.5TD
Old 05-22-2014, 12:11 AM   #17
fluffyfreak
Thanks for the info guys. I gotta shorty frame sitting in my carport I was gonna swap to, but I need something to tow my burban, might bite the bullet and buy a 92-2000 3/4 burban.
Old 05-22-2014, 07:04 AM   #18
chevymadness
Wow that's a bummer I piss 6500 pounds don't all newer trucks have standard towing rate of 6500 pounds even the v6 models this is bull****! What were these trucks used for in 82 hauling groceries and fixing wiring Ffs!Im going to rip the whole drive train out and throw it on the damn curb!
Old 05-22-2014, 07:19 AM   #19
BigBlocksRule
You're a riot - *****ing about wrenching on trucks and you want a BOAT?
By definition, BOAT stands for "Bust Out Another Thousand". My sister-in-law said that a boat is a hole in the water than you throw $100 bills into.
C-10's were built for farmers, contractors, etc., not folks that wanted to tow big trailers - that's what 1-ton trucks were built for.
BigBlocksRule is offline   Reply With Quote
Old 05-22-2014, 07:38 AM   #20
Keith Seymore
Been driving C10 SWB 2wd trucks (6 cylinder/manual trans) for about 45 years now.
We (my family) use them for daily transportation, occasional light towing and hauling (aka "parts chasin', hauling engine blocks, sand bags, cement blocks, towing to the drag strip, retrieving the kid's broken down vehicles).
K
1979-1986
1986 - 2019
Old 05-22-2014, 08:07 PM   #21
fluffyfreak
I gotta bagged burban and bagged S10 that I wanna tow to shows, figured the easiest route would be turnin my halfer into a 1 ton dually and call her done, i know that if I was just pullin the dime the truck would be fine ( with a blower of course) but the 2 plus the trailer would be a bit much. Guess I need to let my marbles drop and step up to a true dually huh
Old 05-22-2014, 09:38 PM   #22
BigBlocksRule
The difference between towing with a half ton and a one ton is very noticeable. The dually rearend lessens the load on each tire, plus those honkin' springs can take the weight. Brakes are huge, front and back. Tow a decent load once or twice with a dually and you won't care to mess with a half ton for anything but your motorcycle trailer.
