![]() Join Date: Nov 2010
Just put new front wheel bearings and seals last weekend. Need some help for future reference. Front end is only thing I haven't rebuilt on my '67. Previous owner or someone put disc on front. Bearings were found to be for HD rotors. My '67 has 2" CPP drop springs (found # on em) and Chassis Tech drop spindles (unsure of drop amount no numbers). The upper control arms have bolted on ball joints.
Sooooo....How do I tell what year of parts I currently have on truck so I can buy in future when they wear out? I bought the bearings for a '75 but found those crossed with a bunch of other years. I'm guessin I have mostly a 73-87 setup but I'm not for sure. How to tell? Give me any and all info. Thanks |
I'm just glad to be here!
Re: Front End Conversion Year?
With the information you gave, its a bit hard to know exactly what you need as there are alot of options within the same parts listed....
Wheel Bearings - you stated that you used '75 model HD bearings. This leads me to you have 1 1/4" thick rotors. If so, then any year '73-'87 with the 1 1/4" rotor wheel bearings work. Ball Joints - This can be tricky...All upper ball joints from '63-'87 trucks bolt into the same mounting pattern as you described. Question for you: Does your Upper and/or Lower A-arms have rubber bushings or steel bushings? Rubber bushings started in 1973. Outer Tie rods - This can be tricky too...many companies sell drop spindles that are year specific and that effects the ball joints and tie rod ends. Some pictures of what you had could/would be helpful for others to help you get the info you are looking for.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
67-72 parts collector,…
![]() Join Date: Nov 2002
Balljoints, tie rods and spindles all have to match.
73-87 would all be the same. Bearings will be rotor specific. Just like the calipers. 1" light duty or 1-1/4" HD rotor width.
Pics of your suspension would also help.
Pics wil follow. Later or tomorrow. Thanks for help.
Ok here comes some pics........hopefully...........
1.
2.
3.
4.
5.
6.
I'm guessing I've got 73-87 rotors, calipers, and pads.
I know I've got HD rotors. No idea of ball joint or tie rod year(s). Guessing stock year control arms. Guessing stock year match for the Chassis Tech (no part #'s) drop spindle. Educate me. |
#14 | |
A-arms could be 67-70 or 71-72. Steel brake line routing is on the front of the crossmember, which means 71-72. My "guess" is 71-72 drop spindles. The ONLY WAY to know for sure,... is to verify the UPPER ball joint or the outer tie rod. They will be either 71-72 specific,... or,... 73-87 specific. Take one or the other to a parts store and verify what you have.
#15 |
^^^ Much appreciated.....again lolife99.
If anyone is seeing anything else let me know. Thanks. |
#16 |
Follow Keith's advice. I see the same thing...
#17 |
![]() Join Date: Sep 2007
Guys... arent those slide on rotors? It looks like the lugnut studs arent pressed in the rotor
Im probably wrong but im just noting what I see.
1967custom |
#18 |
Nope, those are not slide on rotors. I have seen some with chamfers on that side of the rotor at the lug holes...
#19 |
Ya they're not slide on.
