Old 05-22-2014, 09:17 AM   #51
dieseldude4bt
Re: MPG comparison...How's yours?
I mostly just use it for overdrive but when you are towing it is nice to be able to split gears.
I have had it for 16+ years and it was used when I got it so they hold up well.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 05-22-2014, 11:33 AM   #52
66customcamper
Haven't checked for quite a while but was around 10 mpg with 327/4bbl/sm420/
4.56 gears/7.5x16 bias plys running empty. With about 3000 lbs of firewood, I think it was around 7 or 8
66 Custom Camper
327/ 4 spd.
Bone Stock, down to the split rims
66customcamper is offline   Reply With Quote
Old 05-22-2014, 07:19 PM   #53
AcampoDave
AcampoDave's Avatar
Originally Posted by steveb64 View Post
I'm at 9 mpg city, 9 mpg highway, 9 mpg all the time.
Mild+ Cadillac 500, TH400, Holley 870, 3.73 factory limited slip, 28" tires, lots of torque, big right foot.
That's the funny thing about those motors. I got one still in a Cad and its 11 all the time. I like to tell people it uses five gallons an hour, no matter where I go or what I do.
AcampoDave is offline   Reply With Quote
Old 05-22-2014, 08:00 PM   #54
steveb64
steveb64's Avatar
I need to recheck mine, I may be up to 11 now.
Turns out I had a crack inside my th400 case since assembly and install. Burned clutches and all, may have been experiencing slippage.
steveb64 is offline   Reply With Quote
Old 05-24-2014, 09:53 AM   #55
T Herder
65 GMC K1500 305E V6 with a Mallory Maglite distributor, 1988 GM Throttle Body Injection, SM420 with a married Gear Vendors OD, divorced NP 205 transfer case, 4.56 final drive gears, BFG All Terrain 35's, plus a few other things.
I regularly tow a custom Sundowner 4 horse trailer with a GCVW of 18,000 lb. Log book verification shows the best mileage empty has been 18.61 MPG, worst, 7.2 MPG has been with a max load and pulling 21% grades in 4WD.
Average towing mileage runs 12.5-14 MPG, non-towing with a light load has been 14.8-16.4.
Best regards,
T Herder
T Herder is offline   Reply With Quote
Old 05-24-2014, 11:30 AM   #56
ChrisDollins
ChrisDollins's Avatar
Our 66 got over 15mpg on the hwy. Not sure what it gets mixed driving. Factory rebuild 250 with a hei. 3 speed and 28" tires. Was really suprised with old truck, didn't expect it to get that. Ready to get an overdrive in it and check it again.
Chris
ChrisDollins is offline   Reply With Quote
