Old 05-25-2014, 03:21 AM   #1
DaveTurner
DaveTurner's Avatar
62 LS swap questions
So far everything has gone smoothly. Harness is wired and fuel system is in place. Im at the point to wire the starter.
The LS starter has one large post Bat + and I believe the S terminal.
My question is do I run the existing purple wire from the stock 62 wiring system to small S terminal or is something else required??
I searched the forum and read a couple threads close to what Im looking for but nothing exact.
Thanks Dave-
DaveTurner is offline   Reply With Quote
Old 05-25-2014, 04:11 AM   #2
DaveTurner
DaveTurner's Avatar
Re: 62 LS swap questions
Looks like I should run the existing purple wire to the control side of a bosch relay and send battery voltage (fused) to the smaller post.
anyone ever heard of doing this for the LS swap?
Old 05-25-2014, 04:22 AM   #3
Woogeroo
it's a 3 day weekend... check back in Tuesday.
-W
Woogeroo is offline   Reply With Quote
Old 05-25-2014, 04:36 AM   #4
DaveTurner
DaveTurner's Avatar
lol right,
Old 05-25-2014, 07:28 AM   #5
63 & 64 Bowties
and a few others
I moved this for you to the LS section.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 05-25-2014, 08:06 AM   #6
truckdude239
truckdude239's Avatar
I used the stock signal wire on my 71 to the s post
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-25-2014, 09:37 AM   #7
DaveTurner
DaveTurner's Avatar
I'll try this today and see if it kicks over. Just trying to cover my bases
Old 05-25-2014, 09:45 AM   #8
faribran
On this site I have always heard " it's not happening unless pics are posted"
faribran is offline   Reply With Quote
Old 05-25-2014, 09:46 AM   #9
faribran
I think you are on the correct path with the starter wire.
Old 05-25-2014, 10:01 AM   #10
DaveTurner
DaveTurner's Avatar
Running the small stock purple wire direct or going the relay route?
Old 05-25-2014, 10:10 AM   #11
Hart_Rod
Hart_Rod's Avatar
Factory purple wire to S terminal, battery cable to the big terminal. You can also use the factory purple wire to trigger a relay that applies battery power to the S terminal if you choose. I believe that's the way most new cars are wired. Either way will work.
Hart_Rod is offline   Reply With Quote
Old 05-25-2014, 10:21 AM   #12
DaveTurner
DaveTurner's Avatar
Thanks you guys are awesome! Anyone happen to know what length belt to use if I'm just running the alternator ?
Old 05-25-2014, 10:51 AM   #13
oldman3
oldman3's Avatar
This is what we did on one, hope it helps http://67-72chevytrucks.com/vboard/s...d.php?t=628656.... Jim
oldman3 is offline   Reply With Quote
Old 05-25-2014, 11:30 AM   #14
DaveTurner
DaveTurner's Avatar
Perfect thx
Old 05-25-2014, 02:44 PM   #15
1955 mancave
1955 mancave's Avatar
And this is why I love this site, everyone is willing to help and as of now I have not seen ego's which is nice so no one is talked down on, and the expertise of the guys are top notch, heck all you have to do is look at the work that is knocked out, and posting the work and the steps along with pictures will help keep our hobby alive even when we are not !
I will be following this build and being in AZ. I may run into you.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 05-25-2014, 08:25 PM   #16
DaveTurner
DaveTurner's Avatar
Stock purple wire to small Ls starter post worked perfect. The lm7 started first attempt thanks everyone for all your help!!
