Closed Thread
Old 03-09-2014, 04:35 PM   #26
trinidad
Re: Need help with 1972 chevrolet c30
Originally Posted by ivorton74 View Post
that's the oldsmobile 5.7 diesel...that's probably what it came with from factory...some had 350 and 454 v8 gas engines too
Ok i know nothing about these trucks....can you give me some more info on the 350(engine) of which you speak...looking to purchase an engine/tranny asap
trinidad is offline
Old 03-09-2014, 05:16 PM   #27
ivorton74
ivorton74's Avatar
Check out this wikipedia article...will find all info about the small block chevy v8
http://en.wikipedia.org/wiki/Chevrol...ock_engine#350
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline
Old 05-25-2014, 05:11 PM   #28
trinidad
Re: Need help with 1973 chevrolet c30
updates...oldsmobile 5.7 diesel engine out...chevy 350 in...finally it has a working engine..can drive but i have no brakes for some strange reason...hoping to have that fixed asap
trinidad is offline
Old 05-25-2014, 05:40 PM   #29
trinidad
removed the tray today and started to clean the chassis....a new tray will be built locally...still need to look for a cabin as mine is in terrible shape
trinidad is offline
Old 05-26-2014, 01:21 AM   #30
ivorton74
ivorton74's Avatar
Nice to see u making progress finally. Depending on how long the truck was parked up for the rear wheel cylinders probably gone now and probably check the master cylinder and booster too. Did u find out how much it would cost to import a cab from USA?
Old 05-26-2014, 02:28 AM   #31
frank69
I have a good cab like that but I don't have any idea how u would get it to whatever island you are on.
frank69 is offline
Old 05-26-2014, 11:36 PM   #32
trinidad
it does not have a booster...has some strange braking system... been parked up for atleast 2 years....im going to sart with the lines...
As for shipping, once I can get the cab to Miami...its easy to ship to Trinidad!
trinidad is offline
Old 05-26-2014, 11:40 PM   #33
trinidad
Trinidad & Tobago...
trinidad is offline
Old 05-27-2014, 09:48 AM   #34
flyingtim01
You do have a booster on that truck - but it's not a vacuum booster like you're probably used to seeing. Your truck was a diesel from the factory, which makes no vacuum to supply to the conventional vacuum booster. It has what GM calls Hydroboost, you can see the Hydroboost unit behind your master cylinder. Instead of vacuum assist, you have hydraulic assist power brakes - the hydroboost is driven off the power steering pump.
Now that you've swapped in a gas engine in place of the diesel, you may want to also swap in a conventional master cylinder and vacuum booster, just to simplify things for yourself.
1971 Chevy K20 350/SM465/NP205
flyingtim01 is offline
Old 05-27-2014, 11:28 AM   #35
dmartin1
dmartin1's Avatar
cool! like seeing the foreign stuff. or foreign builds i mean. that body style stuff is dime a dozen everywhere around here. you shouldnt have a problem finding decent parts.
id restore it too being its the only other on the iland lol
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline
Old 05-27-2014, 01:45 PM   #36
trinidad
Thanks for the info....
trinidad is offline
Old 05-27-2014, 01:51 PM   #37
trinidad
Thanks...but the problem is parts...everything has to be shipped/imported form the usa....Trinidad is little tokyo
trinidad is offline
Closed Thread
