Kick panel rust! Help!
Can anyone help me determine where this rust is occurring from on the kick panels? Is water getting in around behind the vents or around the windshield and leaking in & down behind the firewall? I have noticed it every time it rains it's wet there and not sure if its leaking in from in behind or where my leak is coming from. Is this common for most of these truck or do I have a bigger problem than expected. That's the only rust on this truck, the rockers are all solid.
"Now all I need is a shop to go with my shop vac!" ![]() |
Re: Kick panel rust! Help!
My no rust az truck has the same problem, although my biggest hole is about dime sized. I think I narrowed it down to the windshield gasket. I followed the dripping water up the firewall and thought it was dried out/leaking sealant so I pulled the cowl panel off and redid the sealant right at those seams. Didn't fix it! So I believe it's the windshield gasket, in my case it's the only other option.
You could pull your cowl panel and check this factory sealant for it's condition: ![]() |
Have a look at the drip rail seam sealer as well.
Couple ideas as to how the water finds its way..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
Drip rail is best option. The drip follows the a pillar down and drains at front of rocker. This gets stopped up and the result is what most of these trucks show up with at inner kick panels and rocker rust.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
