![]() Join Date: Jun 2010
Re: 1958 Apache 38 Dually Dump Project
Had to fix the inner rear passenger body mount brace and floor under the tank before we could jump into body mounts. Cut the old brace and floor rust out (the body channel underneath was good), fit a new piece and welded it in.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
Spent way too much time making a new bottom half for the brace
Got the cab positioned and welded in the rear mount along with frame gussets. Also whittled a couple pieces of the 3" channel down to fit across the top of the frame for the front body mounts/rad support, used the same poly urethane bushings there too...only one between body and mount though...the driver side mount just barely clears the steering gear box.
#4 | |
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
I'm interested to see how you rebuild the doors and hinges. My Cummins 55 truck doors rattle like a recycling bin on square wheels.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
