Closed Thread
Old 05-25-2014, 09:15 PM   #701
franken
Re: What did you do to your truck today? Chapter II
I mocked up the NV4500, range box, and NP205...
I think I need to rotate the box a bit left.
2.6 time 1.96 makes for a good cheap setup.
I parted a 91 sub to get the TC so I have 500 in the whole thing and _all_ parts needed to put it together except the clutch fork boot.
franken is offline
Old 05-26-2014, 12:38 AM   #702
74baggedbug
Installed the new aluminum heads and intake
74baggedbug is offline
Old 05-26-2014, 04:49 AM   #703
PowerdbyChevy79
PowerdbyChevy79's Avatar
sweet....
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline
Old 05-27-2014, 09:05 PM   #704
In The Ten Ring
Today I cleaned up more of the vent line....I didn't think it was possible but I freed up that spring that is around the engine end of the canister line (1972 EEC).
I used Krud Kutter phosphoric acid from Lowe's and after a 2 hour soak it came clean.
In The Ten Ring is offline
Old 05-28-2014, 12:08 AM   #705
allchevy58
allchevy58's Avatar
I have my seat being reupholstered with original fabric and vinyl from SMS, laid down some sound deadener and insulation and installed new carpet from ACC.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 05-28-2014, 11:25 PM   #706
In The Ten Ring
I like that sound deading stuff!
I sprayed NAPA Rust Inhibitor onto the vent line I derusted yesterday.
Old 05-29-2014, 05:43 PM   #707
outlaw 3454
outlaw 3454's Avatar
playing with my vinyl cutter and lettered the truck, not sure if it like it or not.
also found some really trick marker lights and they are gm, check it out.
outlaw 3454 is offline
Old 05-29-2014, 06:35 PM   #708
9teen69
9teen69's Avatar
Allchevy58- looks good, I'm doing the same, where did you screw the under dash light mounts into, did you have to drill a hole?
Outlaw- they look smooth, and the decal looks cool!
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 05-29-2014, 06:48 PM   #709
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today? Chapter II
Did some paint work on the truck the other day and have the front half waxed! I did the paint repair last year too before the HRPT. It takes a couple of days to do but worth it I think. I start by wiping the whole area down with mineral spirit's . Then dry good and use my touchup paint and dab it on in the bad spots. Let it dry good for 2 days and then take a clean tee shirt and mineral spirit's again and rub until smooth. Then wipe off good and wax it.
Here is the front of the hood with paint dabed on and then after I waxed it. It's not 100% but way better than what it was.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 05-29-2014, 07:05 PM   #710
BugzC10
BugzC10's Avatar
Nice job! I like it. At least you can peel it off if you get tired of it.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 05-29-2014, 08:29 PM   #711
In The Ten Ring
I painted my canister lines (those under the truck) with 1 coat of flat black today. Tomorrow I hope to put those back on.
Old 05-30-2014, 07:53 PM   #712
Green69c10
Finished the Restoration yesterday and just have been sitting back and looking at her
Green69c10 is offline
Old 05-30-2014, 08:39 PM   #713
BugzC10
BugzC10's Avatar
One teaser picture is not going to get it....we have to see more of your outstanding work.
BugzC10 is offline
Old 05-30-2014, 09:25 PM   #714
Motoxrrar
Purty truck, always love green.
I made a crafty mount for the DLC. Used a paint chip sample to make it and found a home in this factory hole that had a switch for the saddle tanks.
Used it to make a template but it's pretty sturdy so I may just leave it there....
And forget the effort of making one out of thicker steel. Thoughts?
1972 GMC Sierra Grande
Factory Tool Box
4.8L Ly4 with whipple supercharger.
356 dana 60
4l80e overdrive
Motoxrrar is offline
Old 05-30-2014, 10:06 PM   #715
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I had a toggle switch there and moved it. I was worried what it would do to my knee or leg in an accident. Jmi
Tom Vogel is offline
Old 05-30-2014, 10:39 PM   #716
el_bole
Most of the heavy lifting is done on my 61' so I decided to sand down "rails" of bed to get em ready for paint....It's been so long since I broke down the beds(yes two beds, long story) that I forgot where this "short rail goes". Its the one in forefront of photos... Where does this piece belong???
thanks in advance....
el_bole is offline
Old 05-31-2014, 12:14 AM   #717
Ridgeclimber
I got the box sides, bulk head, steps and cross members assembled and sitting on the frame. Next I have to mount the rear fenders and box side filler tube to the fuel cell.
Ridgeclimber is offline
Old 05-31-2014, 01:01 AM   #718
allchevy58
allchevy58's Avatar
The two holes were already there from factory.
Old 05-31-2014, 01:04 AM   #719
Motoxrrar
Where did you buy the lights from?
Old 05-31-2014, 07:22 AM   #720
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Fixed my horn button, swapped my gauge bezel lights for leds and replaced the shift indicator glass fibre light with an led, rebuilt that annoying little spring button thing that releases the headlight switch shaft! What a PITA.! Now to get on the rack and straighten my back.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline
Old 05-31-2014, 10:16 AM   #721
Andy4639
Old member
Andy4639's Avatar
Polished and waxed the wheels in preparation for the 2014 HRPT next week.
Got the oil changed and all the fluid levels top off too. Added a little color to the pulley's as well!
Andy4639 is offline
Old 05-31-2014, 05:50 PM   #722
ironbutter
Picked my parts up from powdercoat yesterday and then got my engine compartment back together after spraying out the inside of my fenders with a color matched rattle can...
ironbutter is offline
Old 05-31-2014, 09:24 PM   #723
Saclandman
Saclandman's Avatar
Things just got serious. The tear down begins.
Pulled the cowl and driver's side front fender off. Spent a few hours trying to straighten it up and beat the wrinkles out. Not a bad start and much better than it was. Then, I painted my aluminum intake to get ready for the engine swap.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 05-31-2014, 10:57 PM   #724
allchevy58
allchevy58's Avatar
Got the under dash lights from board member thelonerife thread TN Underdash lights. Bulbs are cheap LED's from Ebay.
Old 05-31-2014, 11:45 PM   #725
allchevy58
allchevy58's Avatar
Looking good!
Closed Thread
